Change leaf spring bushings
Old Apr 2, 2023 | 05:15 AM
Niggi's Avatar
Niggi
Hello,
I need your help again. I'm in the process of changing the bushings of the leaf springs on my F250 Bj. 71. I ordered from LMC Trucks for my model with Flexomatic to the best of my conscience, but the diameters don't quite fit. Have any of you had any experiences with this? Here some pictures.
Old Apr 2, 2023 | 02:20 PM
FuzzFace2's Avatar
FuzzFace2
What is that you are measuring the old bushings on as that dose not look like any leaf spring I have seen
You either ordered the wrong bushings or you are not measuring leaf spring bushings.
There should be 1 bushing in the front spring eye that fits into the frame bracket.
Then there is the 2nd one in the rear spring eye that fits into the shackle.
The last bushing would be in either the other end of the shackle or in the frame.
So each side should have 3 bushings for a total of 6 to do the rear suspension.
Dave ----
Old Apr 2, 2023 | 11:36 PM
Niggi's Avatar
Niggi
Hello Dave, my F250 has the Flexomatic so I need 4 bushings for one side. In my pictures above show this component from flexomatic.
Best regards
Manuel
Old Apr 3, 2023 | 04:17 PM
FuzzFace2's Avatar
FuzzFace2
Well that is a first for me
I would say if you have a local spring shop by you see them as they should be able to help.
Sorry I cant help more.
Dave ----
Old Apr 3, 2023 | 08:04 PM
lilorbie's Avatar
lilorbie
Gee something from lmc that don't fit.
Old Apr 3, 2023 | 09:35 PM
5starCabF-3's Avatar
5starCabF-3
Over load
1972 F 250 camper special
Old Apr 3, 2023 | 11:42 PM
Niggi's Avatar
Niggi
Yes, the LMC bushings doesn´t fit, what a ****.
bullnose1985
29
Jun 24, 2023 11:13 AM
Ezalycasaid
Feb 22, 2020 09:00 PM
jbounds
Apr 27, 2012 12:11 PM
polarspeed
15
Aug 3, 2011 08:04 AM
Roger T. Pipe
Sep 8, 2008 11:03 PM
