Sponsored by: Real Truck
Parking Brake Light
Old Mar 30, 2023 | 12:23 AM
ChevyHauler's Avatar
ChevyHauler
1st Gear
Parking Brake Light
Hello looking for guidance just redid the bed and frame on my 2007 F250 and left my truck sitting outside covered up for a couple months in the cold while redoing the bed. Upon moving the truck to bring it inside the shop to do the frame I noticed the truck had the red parking brake light on? Roughly troubleshot the more common issues like leaving the parking brake on, leaking fluid, low fluid etc but none of these were an issue and I was going to check the brake fluid level sensor and the parking brake sensor but is there any other obvious things I'm missing? Instrument cluster replaced 15-20k miles ago by ford dealership the truck brakes strong no issues I just installed all new brake pads and rotors all the way around and new rear calipers while in there inspected all the lines and bleeder screws no leaking and the cap on the master cylinder did not indicate air in the lines the only thing I can think it would be would be those sensors?
Old Mar 30, 2023 | 07:20 AM
user 195474726373's Avatar
user 195474726373
I know that on the 2006 F150 there is a problem with a bad solder joint on a printed circuit under the dash that causes this. Could be others.
Ksnarf
Mar 7, 2009 02:32 PM
Pete in Maine
Aug 21, 2008 12:22 AM
aph453
Jan 29, 2005 11:04 AM
Shadowe
Jan 14, 2005 06:10 PM
saltzy
Oct 6, 2004 12:30 PM
