Headlight switch wiring replacement
Old Mar 28, 2023 | 12:22 AM
DiogenesJay's Avatar
DiogenesJay
8th Gear
About a month ago, we had some snow; possibly first time truck has ever been in snow. I started the truck before daylight to let it warm up and also turned the parking lights on so I could see the gauges. Not long after, I smelled something burning and found two wires melted behind the headlight switch.
Larger plug: Pin #10 - Tan/White - Park lamp relay
Larger plug: Pin #12 - Brown - Power, exterior lamps
I found fuse #17 (exterior lamps) had a 30amp instead of 15amp so I assume that's why the wires ended up melting. I assume there is further damage in the harness because my dash lights and cab lights now come on with the switch turned off.
I need to get this fixed but not sure what caused it to begin with. More importantly, I need to get the harness from the switch replaced. Is it possible to do so without removing the entire dash? What's the best way to tackle this? Any guidance would be appreciated because the task seems like it will be a bear.
Old Mar 28, 2023 | 06:47 AM
SkySkiJason's Avatar
SkySkiJason
That ‘headlight switch harness’ is part of the dash wiring harness. Not exactly an easy fix or swap.
There must have been a short or an overloaded circuit to cause this problem. I think that should be addressed first. If the circuit is working now with correct fuse, maybe it’s an intermittent problem? I would look for chaffed wires near the exterior bulbs first and then work my way back down the harnesses to the fuse block.
I know the upfitters did a SUPER hack job on my cab chassis truck when they installed the flatbed. Per SOP, they hacked the main harness to back of truck just behind cab and installed quick splice wire taps in a big bundle then loosely wrapped tape around it to insure it would hold moisture and slowly degrade the now exposed copper in the harness. This lasted about 3yrs before I had issues and lost my temper discovering what they had done and completely re wiring the flatbed and trailer connections.....
Old Mar 28, 2023 | 11:26 AM
DiogenesJay
8th Gear
That is disappointing news, I really didn't want to tear the dash apart.
I still don't have parking/running lights but I've yet to find the trouble spot. It was my thinking that maybe the snow had caused the short somewhere. I do have a service bed so there could be a mess of wiring in it which I haven't discovered yet.
Old Apr 2, 2023 | 12:32 AM
DiogenesJay
8th Gear
Can someone confirm if the tan/white wire goes directly from the switch to the fuse panel? It appears so but just wanted to make sure.
Also, anywhere I can find new terminals/pins for the connectors? Is that a dealership only item?
stuckinthesnow
Electrical Systems/Wiring
Oct 26, 2023 09:22 PM
marine09
Sep 1, 2015 07:58 PM
soulwinnerrj
Oct 31, 2007 07:55 PM
franco99
1978 - 1996 Big Bronco
Feb 8, 2006 03:25 AM
slifer
May 16, 2004 06:00 PM
