Piston delipping specs?
Old Mar 28, 2023 | 10:16 AM
callforfire's Avatar
callforfire
Speculation is pretty much the entirety of the DIY column. Things like, would anodizing the pistons before coating do anything good?
Since I don't imagine the folks providing the service are going to be specific in their findings, I guess I'm your Bartleby... I would prefer not to.
but I'll do it anyway and post pics.
I did find an old swamps video machining pistons on yt. They took off a lot of meat.
I get cnc envy so bad watching stuff like this.
Old Mar 28, 2023 | 10:44 AM
Dan V's Avatar
Dan V
I forgot to mention that Swamps also ceramic coated my pistons so maybe that made up for lost volume? They did not share specifics with me so I am speculating at best.
Leonard, you're a smart man....how thick do you suppose the ceramic coating is?
Old Mar 28, 2023 | 10:48 AM
Dan V's Avatar
Dan V
Anodizing come in really two flavors, which are outlined at the link. I use this company for SOME of my plating/finishing needs. You would need to know the alloy the pistons are made from.
Anodizing
Old Mar 28, 2023 | 10:54 AM
Dan V's Avatar
Dan V
https://youtu.be/O583ULInRbc
And HOLY CR***P is that a terrible set-up.
Old Mar 28, 2023 | 10:58 AM
FordTruckNoob's Avatar
FordTruckNoob
Not sure if sincere compliment or sarcasm. Odds are it is the latter.
To answer the question: I have no clue.
Old Mar 28, 2023 | 10:59 AM
Dan V's Avatar
Dan V
@callforfire This is crazy full 5 axis machining.
Old Mar 28, 2023 | 11:24 AM
callforfire
I'd be so caught up in my own projects I could never make a living with a machine like that. I'd be on the corner with the other bums holding a sign "need metal every bit helps".
Watching that I was thinking hmm... Ti pistons...
It's bad enough with my little home gamer mill.
Old Mar 28, 2023 | 11:29 AM
callforfire
I noticed that first skim cut looked like it ran out shallower than it started. Then I wondered how many pistons got launched.
Old Mar 28, 2023 | 01:08 PM
FordTruckNoob
At least you have a mill. All I have is a wannabe drill press.
Old Mar 28, 2023 | 01:40 PM
SkySkiJason's Avatar
SkySkiJason
Looked like first pass was to reduce piston height. Maybe to reduce compression or to compensate for decking the block?
Then reliefs for valves to allow for more valve lift/duration (performance cam).
Old Mar 28, 2023 | 08:05 PM
callforfire
Yeah well, I don't have a coke machine.
Mine is a variation of the sieg X2.7L, a WEN 33075T. I just happened to catch it on sale a few years ago with free shipping, just under $1600 I think it was. Got some issues and some mods but surprisingly capable for what it is.
Old Mar 28, 2023 | 08:08 PM
FordTruckNoob
That is actually my powder coating oven.
Old Mar 28, 2023 | 08:19 PM
  #28
callforfire
You have powder coating? Inside a coke machine?
Okay, you win the shops.
Old Mar 29, 2023 | 06:51 AM
  #29
Dan V's Avatar
Dan V
Ah so.....
Old Mar 29, 2023 | 07:29 AM
  #30
Wes444's Avatar
Wes444
And here I was thinking he had a coke problem
