Power Steering Fluid Puddle
Old Mar 26, 2023 | 06:47 PM
aroesti's Avatar
aroesti
Happy Sunday everyone.
I went to check the brakes on my truck today. I had it jacked up, wheels off, engine off, and turned the steering wheel to access the right caliper a little more easily.
As I turned the wheel, I heard squirting, and suddenly there was a quite sizeable power steering fluid puddle on the floor. I'm not 100% sure, but tracing it it seems like it came out the top of the power steering reservoir cap, which did not seem to be on completely.
Does turning the wheel with the engine off lock-to-lock somehow create a lot of pressure in the system? Is any of this cause for concern or should I be good to go with just properly tightening the reservoir cap?
Thanks in advance,
André
Old Mar 26, 2023 | 07:38 PM
Prototypemech's Avatar
Prototypemech
Never heard of that one before. Turning the wheel with the engine off does cause fluid to move around the power steering system, but not any more than normal. Did top off you power steering fluid and accidently overfill it before this happened?
Old Mar 26, 2023 | 07:55 PM
aroesti's Avatar
aroesti
Thanks for the quick response.
I refilled the power steering fluid 200+ miles ago after replacing the gear box. But maybe today was the first time turning the wheel with the engine off again, I can't say that for sure.
When I tried to get it to do again, (turn wheel lock-to-lock a couple of times), it didn't do it again.
Old Mar 27, 2023 | 11:33 AM
manicmechanic007's Avatar
manicmechanic007
Older fords with the C2 pump, and the little air bleed hole in the cap, will do that every time
Either turn real slow, or start the engine
Working the air out might take you a few
Old Mar 28, 2023 | 12:52 AM
aroesti's Avatar
aroesti
Thanks! The cap does have an air bleed hole, so I'm assuming I have the C2 pump. Nothing to worry about then.
Old Mar 28, 2023 | 06:46 AM
manicmechanic007
Right, nothing to worry about but a little mess
If you raise the wheels it is easier on the pump when working the air out
bad_idea
Nov 10, 2020 05:36 AM
Loumos4
Large Truck
Jan 7, 2016 06:35 AM
cory5517
Jan 14, 2012 03:13 PM
FordSDF250
May 28, 2010 10:30 AM
redwood
Dec 1, 2005 12:53 PM
