P0320 code
Old Mar 25, 2023 | 09:47 PM
Anthony Carl Gower's Avatar
Anthony Carl Gower
P0320 code
Okay, so I'm getting PO320 code, 13 F150 3.5, which points to cam shaft sensors, crankshaft position sensor, or low voltage. Come to find out that 1 of my cells was bad in my old battery[/color][color=#383a3b], so I bought an upgraded battery, Motorcraft, rather than what it calls for to accommodate the cold weather. I had a crankshaft sensor from the old motor and just moved around the sensors. Now it won't start at all. So Im thinking the crankshaft sensor is bad. Any ideas? Before I changed all these, it at least ran just when you accelerated fast, then it would give me the wrench, but if I drove normal, never throw the wrench
copyman
New Member Introductions
Dec 16, 2006 12:48 PM
