I just picked up a 2016 250, Doing some research on things to look out for and the CAC tube looks stock and worn. Do I really need to spend $300 to get a good one? What do you guys recommend? Thanks Ben
It's up to your personal preference. The stock part is a known part that fails while towing. If it blows while your towing it will leave you stranded. The Stock Replacement CAC is over $100. After market kits are anywhere from $150-$350 and are made with silicone and aluminum versus plastic compared to the OEM offering.
I chose to spend $300 on an aftermarket kit and be done with it and never have to worry about it again. You can carry a spare stock part in the truck if you so choose.
I would swap it out. In fact, when I got my 22, that was the first part I swapped out. I went with an S&B CAC pipe and it was obvious at how much better the S&B part was over the stock part. However, I did throw the stock CAC pipe in the back of the truck... who knows, I may meet someone else one day that needs a new CAC pipe! But given the issues with the stock CAC pipes, especially the earlier models like yours, I would just spend the money once and get a good quality pipe and be done with it.
Im with you, I dont want to ever have to change it again. Most of the $300 ones im seeing are pretty LOL, I dont care about pretty. If theres a cheaper one that holds up just as good for a lower cost id be OK with that. Just looking for advice.
I'm not really familiar with anything other than the 22's... but it seems like Rudy's has been mentioned for lesser expensive options. Not really sure.
If I had to do it again (have a Rudy's), I'd do a one piece silicone hose cold CAC pipe from SPE and H&S. S&B has one as well. These are the one piece (one silicone hose with throttle body adapter and yes, are more... AFE also makes one but not cheap and not one piece.
For cheaper options, these have two hoses and two metal pieces.
I see what you mean. Thanks for the help everyone.
No problem... helpful bunch here. Even though the two piece set is more, they're probably easier to install, I would think. Let us know what you go with... good luck.
I had a set of Rudy's intercooler boots/clamps/pipes on my old 6.0; the pipes seemed fine and so did the boots until I started towing in the August heat one day. I was blowing boots right and left. I tried hair spray, new clamps, everything under the sun and could not get those boots to hold. It turned what was going to be a 12 hour trip pulling our camper into a 2 day fiasco in 100+degree heat. That said, I would be very hesitant to buy or recommend any silicone coupler from Rudy's for any application so take that for what it's worth. When I replaced the boots with Riffraff Diesel parts the issue went away.<br />My 19 still has the stock cold side boot (90K miles so far) but I would like to replace it soon, thanks also to an experience with my old 6.0 pulling a camp trailer when I popped the stock plastic CAC tube at around 22psi boost (hence why I bought the parts from Rudy's). That was a VERY loud bang and made for a slow rest of the trip home running with no boost!<br />
