77 to 79 Circular Headlight Bracket
Old Mar 24, 2023 | 02:48 PM
Msaluta's Avatar
Msaluta
I'm looking to update my 1979 F100's headlights. I purchased some LED headlights that are in the shape of a circle instead of the standard square for this year. I also purchased circular headlight shrouds that the headlights rest in.
I removed the stock headlights today, and as I expected there are some non-compatibilities. The bracket that the headlight would normally fit into is also square.
My question is, if I purchase brackets from this vendor: https://eclassics.com/eclassics-1970...EaAk2GEALw_wcB
Would that mount up to the current setup? If so, would there be any other bracket/cup/mount issues I'd need to look at when switching to circular from square headlights?
Old Mar 24, 2023 | 04:13 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
The headlight shape is based off the trim package, not the year. A "Custom" package (lowest package available, for like fleet trucks) even in 79, had round headlights. So you are having the old classic I want 7" round headlights instead of the rectangle headlights dilemma. Yes you need the round bucket and you might even need the L round headlight bracket that the round headlight bucket mounts to. I have sold the L bracket and the round bucket as a package deal in the past. I am currently out of stock.
Same deal when you go from a 78/79 to a 73-77 grill set up. Use same 79 core support and just drill new holes for the L brackets. I believe there are drill dimples in the core support. https://www.ford-trucks.com/forums/1...rill-swap.html
I am sure someone can confirm if you need the L brackets for round headlights also. NOT mine, but maybe more of what you need to look for.
https://www.ebay.com/itm/23492638484...4aAlEIEALw_wcB
High_HP
Mar 19, 2022 03:42 PM
ZachT93
42
Dec 5, 2021 10:49 PM
SteelHorse08
2004 - 2008 F150
May 21, 2008 03:44 PM
beartracks
Aug 31, 2001 07:18 PM
