Drive shaft issues
Old Mar 23, 2023 | 07:48 PM
best970bullnose's Avatar
best970bullnose
1st Gear
Drive shaft issues
Hi guys, I have a 1984 f150 single cab long bed 133wb, with a 4-speed manual with a 9-inch rear I recently rebuilt an np208 that has a fixed yoke.
Now for the problem I have a slip yoke rear shaft and now I'm puzzled because the driveshaft will be slightly shorter, has anyone else swapped a fixed rear yoke into their 84 if so what driveshaft did you need and how long was it. or what truck can I get a shaft from that will work.
Old Mar 23, 2023 | 11:29 PM
BigBlue2's Avatar
BigBlue2
I have had drivelines made for me at a driveline shop. Search driveline shop "your town"
Old Mar 24, 2023 | 07:26 AM
Max Capacity's Avatar
Max Capacity
Agree, search locally. Most any heavy equipment repair shop will have a local contact too, or any old auto repair shop that's been around for many years. I my area CT there are many auto repair shop that fix all kind of vehicles. They have new car's to 30 year old trucks sitting outside all the time, even mail trucks.
Old Mar 24, 2023 | 07:49 AM
Franklin2's Avatar
Franklin2
They made it, the list below is all the different combinations they made in 1984. Finding it will be the challenge.
139" WB, MT, front section, Ford manufactured, 3 speed transmission
139" WB, MT, front section, Ford manufactured, 4 speed transmission
139" WB, AT, front section, C6 transmission
139" WB, MT, front section, New Process manufactured
139" WB, MT, front section, Warner manufactured
155" WB, AT, 4x2, front section, C6 transmission
155" WB, AT, 4x4, front section
117" WB, MT, 4x2, New Process manufactured
133" WB, AT, 4x2, 2 piece, rear section
117" WB, AT, 4x2, AOD transmission
133" WB, AT, 4x2, 1 piece, C6 transmission, non-removable carrier
133" WB, AT, 4x2, 1 piece, C6 transmission, removable carrier
133" WB, MT, 4x2, 1 piece, Ford manufactured, 3 speed transmission, non-removable carrier
133" WB, MT, 4x2, 1 piece, Ford manufactured, 3 speed transmission, removable carrier
133" WB, MT, 4x2, 1 piece, Ford manufactured, 4 speed transmission, non-removable carrier
133" WB, MT, 4x2, 1 piece, Ford manufactured, 4 speed transmission, removable carrier
133" WB, MT, 4x2, 2 piece, front section, Warner manufactured
117" WB, AT, 4x2, C6 transmission
117" WB, AT, 4x4, flange joint (thru 1/84)
117" WB, AT, 4x4, slip yoke joint (from 2/84), non-removable carrier
117" WB, AT, 4x4, slip yoke joint (from 2/84), removable carrier
117" WB, MT, 4x2, Ford manufactured, 3 speed transmission
117" WB, MT, 4x2, Ford manufactured, 4 speed transmission
117" WB, MT, 4x2, Warner manufactured
117" WB, MT, 4x4, flange joint (thru 1/84)
117" WB, MT, 4x4, slip yoke joint (from 2/84), non-removable carrier
117" WB, MT, 4x4, slip yoke joint (from 2/84), removable carrier
133" WB, AT, 4x2, 2 piece, assembly (ID 4R602)
133" WB, AT, 4x2, 2 piece, front section
133" WB, AT, 4x4, flange joint (thru 1/84)
133" WB, AT, 4x4, slip yoke joint (from 2/84), non-removable carrier
133" WB, AT, 4x4, slip yoke joint (from 2/84), removable carrier
133" WB, MT, 4x2, 2 piece, rear section, non-removable
133" WB, MT, 4x4, flange joint (thru 1/84)
133" WB, MT, 4x4, slip yoke joint (from 2/84), non-removable carrier
133" WB, MT, 4x4, slip yoke joint (from 2/84), removable carrier
139" WB, AT, front section, AOD transmission
155" WB, AT, 4x2, front section, AOD transmission
155" WB, AT, 4x2, rear section, non-removable carrier
155" WB, AT, 4x2, rear section, removable carrier
155" WB, AT, 4x4, rear section, non-removable carrier
155" WB, AT, 4x4, rear section, removable carrier
133" WB, AT, 4x2, 1 piece, AOD transmission
133" WB, MT, 4x2, 2 piece, front section, Ford manufactured, 3 speed transmission
133" WB, MT, 4x2, 2 piece, front section, Ford manufactured, 4 speed transmission
133" WB, MT, 4x2, 2 piece, rear section, removable carrier
139" WB, AT, rear section, non-removable carrier
139" WB, AT, rear section, removable carrier
139" WB, MT, rear section, non-removable carrier
139" WB, MT, rear section, removable carrier
155" WB, MT, front section, 4x2, Ford manufactured, 3 speed transmission
155" WB, MT, front section, 4x2, Ford manufactured, 4 speed transmission
155" WB, MT, front section, 4x2, New Process manufactured
155" WB, MT, front section, 4x2, Warner manufactured
155" WB, MT, front section, 4x4
155" WB, MT, rear section, non-removable carrier
155" WB, MT, rear section, removable carrier
117" WB, AT, 4x2, C5 transmission
133" WB, AT, 4x2, 1 piece, C5 transmission
133" WB, MT, 4x2, 1 piece, New Process manufactured, non-removable carrier
133" WB, MT, 4x2, 1 piece, New Process manufactured, removable carrier
133" WB, MT, 4x2, 1 piece, Warner manufactured, non-removable carrier
133" WB, MT, 4x2, 1 piece, Warner manufactured, removable carrier
1984 Ford Truck-F150
Drive Shaft, Rear
[/i]
Old Mar 24, 2023 | 07:53 AM
Franklin2's Avatar
Franklin2
Where do you live? Here is a small sample of what came up on www.car-part.com.
1984
Rear Drive Shaft
Ford Truck 250 COMPARE BEFORE SALE A LIF362 $150 Knik Towing & Wrecking (Alaska) USA-AK(Wasilla) parts@KnikRecycling.com?subject=Car-...50%2C%20LIF362 1-907-376-2584 1983
Rear Drive Shaft
Ford Truck 150 31.5WTW A NOF $150 Tom's Used Auto Parts USA-CT(Bristol) Request_Quote 860-582-7056 & 800-824-0025 Request_Insurance_Quote
1984
Rear Drive Shaft
Ford Truck 150 MATCH UP 33WTW A NOF $150 Tom's Used Auto Parts USA-CT(Bristol) Request_Quote 860-582-7056 & 800-824-0025 Request_Insurance_Quote
1984
Rear Drive Shaft
Ford Truck F150 300 CID,4 SP,4x4 48"w to w,60"c to c A 150081 145.75
--Can--
$200.00 Southside Auto Wreckers Can-SK(Weyburn) Request_Quote 306-842-2641 Request_Insurance_Quote
1983
Rear Drive Shaft
Ford Truck 150 48 1/4" W TO W X NOF $125 Farritor Auto Parts USA-NE(Broken-Bow) Request_Quote 308-872-6411 / 308-872-6412 Request_Insurance_Quote
MightyThor
Jul 31, 2017 02:06 PM
J&JProperty
Apr 22, 2009 06:55 PM
tangcoral2004
Jun 30, 2005 12:39 AM
KJKozak2
Jun 24, 2003 11:38 PM
