Carburetor
Old Mar 23, 2023 | 05:00 PM
Daniel N.'s Avatar
Daniel N.
Carburetor
78’ 351m carburetor stud thread count ??
Old Mar 24, 2023 | 07:25 AM
manicmechanic007's Avatar
manicmechanic007
Should be fine thread , 5/16-24
if yours has coarse threads, like some back in the 70s, then 5/16-18
Old Mar 29, 2023 | 12:41 PM
tbear853's Avatar
tbear853
Most all I've seen, studs had 5/16-18 course into the manifold, but 5/16-24 up on carb end.
I've used 5/16-18 threaded rod and run it into the manifold to bottom or just smack the thread to snug the rod in the hole ... then used a nylock nut and washer on the carb end. Not too tight, don't want broken ears. I use wheel bearing grease on my carb to manifold gaskets.
glruff
S. California Chapter
333
May 15, 2008 07:23 PM
Qvan666
Dec 21, 2003 05:32 PM
