Sponsored by: Auxito
check engine light p1537/38
Old Nov 16, 2003 | 05:29 PM
dhailey's Avatar
dhailey
Hello,
My check engine light is on and show a p1537 and p1538 code
which is a Intake manifold runner control
where is it located what does it look like and how can I repair it
How much would it cost to fix
or could it be somthing else causing the failure
Help
Old Nov 16, 2003 | 08:30 PM
dhailey's Avatar
dhailey
More Information
hello.
I own a 1997 Ford F150 V6 4.2
runs great but I have a check engine light
I ran a Diag Test and Got a p1537/38 code
I would like to know more about Intake manifold Runner Control and how to fix it with less money
thanks
david
Old Nov 16, 2003 | 08:36 PM
dhailey's Avatar
dhailey
Question??????
hello,
where can I find a picture of a intake manifold runner control
Old Nov 17, 2003 | 07:35 PM
Racerguy's Avatar
Racerguy
I dont have a picture that I can post here but the IMRC's are located at the back of the lower intake manifold. I dont know if you can see them with the upper intake manifold on or not. I believe they are roundish servos with a vacuum hose and a connector on them with a rod that goes to the actual butterflies in the intake manifold.
I think I would start by checking the vacuum diagram which should be on the underside of the hood to see where the vacuum for the IMRCs comes from and start chasing that.
The codes you are getting mean that both the IMRCs are stuck open when they shouldnt be.
nathan5603
1983 - 2012 Ranger & B-Series
Dec 15, 2011 06:53 AM
kdrifter440
1997 - 2003 F150
Jun 22, 2008 07:27 PM
snikwahttam
1997 - 2003 F150
Dec 23, 2003 04:30 PM
mgb150
1997 - 2003 F150
Oct 27, 2003 08:22 AM
20lbteg
1997 - 2003 F150
Oct 23, 2003 10:04 PM
