ICM question
Old Mar 21, 2023 | 02:59 PM
yeet's Avatar
yeet
ICM question
I have no idea how old the ICM in my 95 F150 is. Everything on the truck is working correctly at this time. The many posts I have read about the heat sink mounted ICM's state that a layer of dielectric grease is needed on the back side when replacing one.
Question one: Is this something that should be regreased periodically while doing general upkeep on the truck?
Question two: How much grease? Am I slathering it with grease or is it a light film?
Thanks!
Old Mar 21, 2023 | 03:19 PM
sandymane's Avatar
sandymane
Dielectric grease will do little to help protect ICM from the heat sink. Thermal Paste Compound or Heat Sink grease is what you should use for best results. Available from Amazon. Not sure about parts stores having it. It is more of a computer product.
Old Mar 21, 2023 | 03:51 PM
yeet's Avatar
yeet
OK.... but the other questions provided I get the proper grease?
Old Mar 21, 2023 | 04:06 PM
sandymane's Avatar
sandymane
I haven't regreased mine in 10K miles. I used a nice layer of grease on mine and called it good.
Old Mar 21, 2023 | 05:08 PM
rla2005's Avatar
rla2005
I would pull off the ICM for inspection. Given the age and hot environment I suspect the existing thermal compound is dried up. I have seen that many times.
A light film of good quality thermal compound is all that is required.
To amend my response...reapplying on a regular schedule is not required. But after 20+ years I would do it as preventive maintenance.
Old Mar 21, 2023 | 05:10 PM
My4Fordtrucks's Avatar
My4Fordtrucks
No. It does not need to be periodically reapplied.
Old Mar 21, 2023 | 08:05 PM
Scndsin's Avatar
Scndsin
Thermal paste is not the same as dielectric grease.
The pastes sole purpose it to actively facilitate the transfer of heat to a heat sink.
Think processor chip in a PC. Use that.
Old Mar 22, 2023 | 05:21 AM
yeet's Avatar
yeet
Ok, I found some on Amazon. Thanks to all. I did not know thermal paste was the proper product. You guys saved me from an expensive mistake.
Old Mar 22, 2023 | 07:47 AM
blazerman07's Avatar
blazerman07
Autozone sells it in a little tube and you get just enough. Paid $5
a few months ago when I did mine.
speakerfritz
Mar 3, 2022 04:34 PM
speakerfritz
6.7L Power Stroke Diesel
Mar 3, 2022 09:49 AM
Flip4ford
Kansas Chapter
22
Jul 24, 2017 07:53 AM
fishforlife2007
18
Feb 15, 2015 02:31 PM
Flatlanded87
Jan 3, 2007 04:51 PM
