Stalling
Old Mar 21, 2023 | 11:12 AM
Felonious Traveler's Avatar
Felonious Traveler
Stalling
94 7.5L EFI in an RV. Idles ok, but when I pull it into drive or reverse, it stalls. If you tap the throttle at the same time you can save it and it will calm back down to a decent Idle. When going from drive to park the engine seems to race a bit, but will again eventually settle down. I checked all the obvious stuff, vacuum leaks, electrical plugs and whatnot. Same thing cold or warm. I'm leaning towards IAC, but thought I'd query the crowd before I start buying parts.
Old Mar 21, 2023 | 12:45 PM
jas88's Avatar
jas88
Clean and reset the IAC first.
Old Mar 22, 2023 | 08:01 AM
manicmechanic007's Avatar
manicmechanic007
You checked all the obvious stuff?
Like codes?
A scan tool with some pid capability?
Make sure the TP pid is above .8v at idle, you could backprobe the sensor connector with a DVOM
Clean the throttle plate and the injectors?
The Maf sensor has a spider web in it?
ftlover90
Jul 22, 2017 01:04 AM
Da_Lariat_Chariot
Aug 1, 2016 12:26 PM
conyers73
Nov 5, 2014 09:25 AM
COLEnMICHAELS66
Dec 12, 2005 02:00 PM
junkntrunk
1978 - 1996 Big Bronco
Jan 14, 2005 12:39 AM
