Latest SYNC Update Problems
Old Mar 20, 2023 | 07:22 PM
machmedic's Avatar
machmedic
My 2022 F-350 Lariat SYNC updated about 2 weeks ago and I was able to make Apple Maps go full screen. It worked great. I come home from vacation today after 10 days and now Apple CarPlay/Maps are only half screen with the other side just a black screen/same whether map is big or small. And also every time I shut the truck off now my screen defaults back to the radio screen when I restart and I have to reselect the previous screen from when I last had truck running. Anyone else having problems?
Old Mar 20, 2023 | 09:17 PM
RedNNBlue's Avatar
RedNNBlue
My truck was at the dealer 3 weeks ago and I asked them to update all firmware on the modules applicable and to update Sync. I haven't had any updates and never got the full screen. I'm beginning to think the updates are BS.
Old Mar 20, 2023 | 10:08 PM
F450_on_44s's Avatar
F450_on_44s
My 2022 F450 was delivered in January 2022 and I have never gotten a Sync update. I have connected to wifi and checked manually several times.
Old Mar 21, 2023 | 07:47 AM
rconnjr's Avatar
rconnjr
Finally got the latest update but now my screens resolution is screwed up and the display does not fit on the screen
Old Mar 21, 2023 | 09:50 AM
Back2Gas?'s Avatar
Back2Gas?
Kind of glad I've had no updates...
Old Mar 21, 2023 | 01:00 PM
kshoop1958's Avatar
kshoop1958
Me too! My last update was 3.5.2 in December of 22. Seems like they are Beta testing with some trucks.
Old Mar 21, 2023 | 10:33 PM
machmedic's Avatar
machmedic
Update. Started the truck this morning and screen is back to working correctly with Apple Maps able to be full screen. Still defaults to the audio screen after every new restart. It’s fun being a beta tester 👎
Old Mar 22, 2023 | 06:42 PM
AZDUALLY's Avatar
AZDUALLY
I got the Alexa and Full screen for Google maps update last week. So far everything is working correctly.
I know with my Ram trucks updates to Uconnect were done in batch's by VIN. SYNC may be the same way so it may take some time to get the updates OTA. Not sure if Ford dealers can push SYNC updates to you - Ram dealers claim they cant update the new Uconnect radios that update over the air.
Old Mar 22, 2023 | 11:35 PM
Lariat Driver's Avatar
Lariat Driver
Veteran: Navy
On March 7, my system updated to 3.5.3. Ever since, my Sync 4 changes to the audio screen every time I restart the truck. Very frustrating because I rarely use the audio screen.
Old Mar 23, 2023 | 07:55 PM
sleddinfool's Avatar
sleddinfool
Some 2023 F-Super Duty vehicles may experience the inability to use a QR code to set up Amazon Alexa™. When a QR code is scanned, the wake word option may not appear on the center display screen to access Amazon Alexa™. This may be due to the accessory protocol interface module (APIM) software and replacement or reprogramming of the APIM may not resolve this condition. Inform customers that engineering is currently working on a solution for this condition and will be released via an over the air (OTA) software update expected in Q2 2023. Customers that have experienced this concern should verify automatic updates are enabled and that the vehicle has been run long enough to receive updates via OTA. Monitor OASIS for additional information.
lots of issues with sync right now.. This is the only one I copied and pasted. Kevin
Old Mar 24, 2023 | 10:24 AM
BEBosworth's Avatar
BEBosworth
Got my update (3.5.3) yesterday and everything seems to work as it should except as noted earlier in that the last two times I restarted the truck it went to the audio screen. A bit annoying as I would much rather have it go to the last screen that was on the display.
Old Apr 15, 2023 | 11:42 AM
Killer Volt's Avatar
Killer Volt
I have a different sort of issue, I upgraded from a 4" screen Sync to a 8" screen, new APIM, ACM,FCIM, and all has been fine, Now I get in the truck start it and at random times the screen stays black, no sound from the radio, I try a soft restart (power and FF buttons together) and it only worked once. However the next time I start the truck everything works fine, it does for no rhyme or reason and can go days with no issue. Anyone have any thoughts or ideas?
Thanks
Old Apr 16, 2023 | 12:05 PM
Lariat Driver
Veteran: Navy
I've also noticed that a restart of the truck will randomly turn the radio On and other times turn it Off.
SteveKoz
Dec 13, 2021 05:18 PM
Project-55
Apr 12, 2013 11:16 AM
arizonasuperduty007
Arizona Chapter
May 8, 2012 04:55 PM
