Rubber Body Mounts
Old Mar 20, 2023 | 01:33 PM
twiebe1776's Avatar
twiebe1776
Trailering
Rubber Body Mounts
I need to replace the body mounts on my 91 F150 and everywhere I look I can only find polyurethane mounts. I'd prefer rubber to keep NVH down as much as possible. Does anyone know where to buy rubber mounts? Thanks!
Old Mar 20, 2023 | 01:38 PM
McLeod's Avatar
McLeod
Like these:
https://shop.broncograveyard.com/198...ctinfo/331800/
What is NVH?
Old Mar 20, 2023 | 01:41 PM
twiebe1776's Avatar
twiebe1776
Trailering
Originally Posted by McLeod
Noise Vibration and Harshness
I understand its an old truck and it'll never be a caddy but I'd like to keep road/wind noise down as much as possible and to have the truck ride as smoothly as possible.
Those mounts are basically what I'm looking for but unfortunately they're double the price of polyurethane. Maybe there's cheaper stock replacement ones? I'm not sure.
Old Mar 20, 2023 | 01:46 PM
McLeod's Avatar
McLeod
These say they are rubber:
https://www.lmctruck.com/1980-96-for...nting-hardware
Old Mar 20, 2023 | 01:50 PM
1r1d1um's Avatar
1r1d1um
Honestly I only recommend the expensive S&B Silicone Rubber bushings/mounts. $450 dollars, but the extraction tools (unless you already have them) will make your life way easier. I ended up breaking the stud on one of these tools because of how tight the factory mounts where. Had to cut a grade 8 bolt (from O'Reillys of all places) to replace the stud to finish the job. Without the extraction tools, you will be cutting the bushings out forcefully. I did the cab last summer and the radiator supports this last weekend. Since the radiator ones don't use the extraction tools, I ended up breaking the bolt head on one side and cutting out the center of the bolt with a reciprocating saw. The other side I had to cut the bolt again in the middle but still wouldn't come out. Had to cut the head of the bolt off (angle grinder) to get the bushing out. Moral of the story, don't cheap out or your curse jar will mighty full when you are done.
Old Mar 20, 2023 | 01:54 PM
twiebe1776's Avatar
twiebe1776
Trailering
I appreciate the advise, I've done body mounts a couple times on clean trucks and it wasn't an issue unfortunately the 91 I'll be working on is a little rougher and I'm already expecting a fight. I'm a little conflicted since the reason it needs mounts is the right rear one is shot and the cab is tweaked just enough that the passenger door doesn't close all the way and there's a whistling wind noise on the highway that's super annoying.
However if the S&B mounts are that much of an upgrade while being softer or as soft as rubber it might be worth it in the long run.
Old Mar 20, 2023 | 01:55 PM
twiebe1776's Avatar
twiebe1776
Trailering
I must be blind I would've sworn I'd looked everywhere on LMC and only found their polyurethane ones. Thank you very much!
Old Mar 20, 2023 | 02:01 PM
1r1d1um's Avatar
1r1d1um
Besides the door being tweaked, I would make sure you door seals are in good shape and the half seal that sits physically on the door is still there. That will reduce wind noise a lot. Disregard if the seals are all there and in good shape.
I don't really have a point of reference to say if the S&B mounts really make a difference for the price. I've never had a truck like this with good factory ones, but I can at least say these are squeak and noise free. Ride quality I can't say as again, no reference, but it feels decent. Really the big thing from this kit is definitely the extraction tools. Good luck.
Old Mar 20, 2023 | 02:56 PM
GoinBoarding's Avatar
GoinBoarding
Good call avoiding poly cab bushings. I put a set in and they suck. One of these days I'll swap them out for rubber. Smooth roads, they're fine but on washboard or freeze/thaw pavement and you'll feel everything.
Old Mar 20, 2023 | 05:25 PM
sswari's Avatar
sswari
I went with The red Energy Suspension set, and haven't noticed any issues. I also did go with Stinger X sound damping all around the cab, which didn't hurt one little bit.
Old Mar 20, 2023 | 07:37 PM
Prototypemech's Avatar
Prototypemech
When it came time to replace my body mount bushings, I went with the SB silicone bushings. Everything was in the kit, including the installation tool. It took about 2 hours to do the whole job. It was pricey, but everything worked wells and the mounts perform well. Very similar to stock rubber with less cab-to-bed deflection.
Old Mar 21, 2023 | 05:38 AM
yeet's Avatar
yeet
Order the free print catalogue from LMC. I ordered one and found they offer many parts that are not shown on the online website.
Bgilmore480
Oct 9, 2017 09:02 AM
bulldogcountry1
Aug 22, 2017 10:40 PM
Watcher58
Sep 27, 2015 01:37 AM
Greg5OH
Aug 11, 2014 08:26 PM
SoupCan™
Mar 2, 2010 10:51 AM
