E4OD Torque converter install question
Old Mar 19, 2023 | 06:14 PM
Dakotap007's Avatar
Dakotap007
6th Gear
I have a 1990 ford f250 7.5l w/ e40d transmission, transmission was rebuilt recently. Now my question, torque converter was installed all the way ( I triple checked it) when I installed the trans into the truck the torque converter was roughly 1/8" from the Flex plate, when I tightened the torque converter bolts the torque converter tightened towards the flex plate, but pulled about an 1/8" from/out of the transmission pump. IS THIS NORMAL?
Old Mar 19, 2023 | 07:01 PM
Scndsin's Avatar
Scndsin
If the TC pulls forward to the flex plate approximately 1/8 inch after the bellhousing mates & as the nuts are tightened, then the torque converter was properly seated.
Old Mar 19, 2023 | 07:03 PM
Dakotap007's Avatar
Dakotap007
6th Gear
Ok cool then I'm good, thank you. I started to freak out a little bit.
Jasonnoel
Apr 23, 2024 08:03 AM
gventura18
Aug 12, 2022 08:19 AM
csuther
Sep 4, 2018 08:30 PM
JOHN2001
Jun 11, 2012 05:55 PM
