General Automotive Discussion
Fuel line connector
Old Mar 19, 2023 | 10:30 AM
Felonious Traveler's Avatar
Felonious Traveler
Fuel line connector
I can not get this fuel connector connected. I know it's supposed to just push together. Are there any special tricks or tools? I used the spring clip tool to undo it with no issues. And please, no comments like "Get your mom to do it" or "Find a girl scout working on her automotive badge" or "You have to lick it first" or some other silly nonsense. Seriously though, this is putting me behind schedule.
Old Mar 20, 2023 | 06:58 AM
JWA's Avatar
JWA
Does the work shop manual show a tool that squeezes the two parts together so they latch or the external clamp can engage?
I have known those type connectors aka "spring lock" to latch together when pushed together---what tool did you use to separate them?
Old Mar 21, 2023 | 10:42 AM
helifixer's Avatar
helifixer
use carb cleaner and spray in the area where the spring is, then blow out with shop air, repeat several times. then flood it with pb blaster and assemble it.
they normally don't lock as they get filled with dirt and grime around the spring and it isn't able to move enough to lock
Old Mar 21, 2023 | 10:57 AM
Felonious Traveler
Update, I was able to get the lines together. Cleaned everything up and the used a channel lock (very gently) to pinch it the last 1/8" or so. Heard a little pop and that was it. Ran 20 minutes, no leaks.
DDT11
Jul 9, 2022 12:33 PM
nathanr561
Aug 3, 2019 05:18 PM
justjake
Jan 6, 2011 06:30 PM
Brewbadoob
Dec 5, 2009 05:55 AM
luke_trash
Jun 27, 2003 10:11 PM
