Help with paint code
Old Mar 20, 2023 | 10:04 AM
McLeod's Avatar
McLeod
he bumper is a ProtoFab Rocksolid rear bumper.
I think I bought it in 2017.
https://protofab4x4.com/product/1980...k-rear-bumper/
The Bronco is once again away from the house today but here is a pic just days after I got it home from the new paint job
They can be used on trucks too with some modifications to the mounting brackets
As I understand it if your tailgate has the OEM aluminum trim (as my original gate did) the trim may come in contact with a part of the bumper.
Old Mar 20, 2023 | 11:15 AM
OBS460's Avatar
OBS460
Originally Posted by McLeod
Here is what applies to my rig.
Just for clarity, mine is a 95 Bronco built in 10/94, so it is an early 95..
It has paint code WM just like yours.
Notice that some charts call it "light opal clear coat metallic" and others call it "light opal poly". The name is not important but the paint code (WM) is what rules.
If you notice the paint formulation number above is M6631A where as everywhere else I look shows the formulation number as being M6631.
Light Opal metallic:
https://paintref.com/cgi-bin/colorco...e=Light%20Opal
So going back to what I mentioned before that I was given a choice between an "A" or "B". I think I am mistaken. I now think that it was an "A" variant that was the option.
I was likely given the choice of M6631 or M6631A equivelant. These are Ford numbers and other paint manufacturers use different numbers for same color.
With that being said, the paint I had purchased from the Carquest store back in 2010 was a single stage made by Third Dimension, which I believe is a Sherwin Williams brand.
This paint formulation number is 54-48459-A . I would assume (oh oh...) that the "A" at the end of the formulation number correlates to the Ford number of M6631A -vs- M6631 that shows on most look up charts.
Now back to what I can report about my specific vehicle, I sprayed an small area inside of one of my door jambs this 54-48459-A paint. This paint is slightly darker that the original paint that came on my Bronco. The original paint has more of a silvery look but new paint is slightly bent to a grayish tone. Not terribly noticeable but a keen eye will see it.
Now, except for the door jamb area that I sprayed, I never used this paint. Instead, I sent it to a body shop to paint the new tailgate and they used PPG 2 stage which was the darker paint and yes you could notice the darker tailgate next to the original paint just above the tail lights.
Fast forward about 8 years and decided to get entire truck repainted. A different shop used PPG formulation for the M6631 and it too is the darker color and the slight color discrepancy over the original paint can be witnessed at the door jamb areas. Most people wont even notice this but it is there.
Given this, my guess is (and this is only a guess so do your own due diligence) is that the earlier production vehicles used the lighter almost silvery color and they later switched to a darker more grayish color later in model year for some reason.
So if you are given the choice of an "A" formulation this would likely be the darker late production color. I would also be speculating here but it looks like PPG defaults to the later production darker gray color.
Yours looks to be a later production 95 given the build date on your data tag.
As a side note, when I used this Third Dimension paint to spray a small area inside of the door jamb I used a Preval sprayer. The spray out was way too heavy for the metallic content and it just looked all muddled and metallics looked awful. Glad it is in a hidden area. So be warned that metallics didn't seem to work well in a Preval sprayer.
Hope that helps some.
Here is a picture of my Bronco wearing the darker WM paint:
My 95 F350 is pant code YY or Colonial White. Your picture shows YY as just White but there was no plain White from Ford in 95.
Old Mar 20, 2023 | 11:55 AM
McLeod's Avatar
McLeod
At a glance they look to be the same shade of white.
Like mentioned before, the name (white -vs- colonial white) of the paint is not relevant, it is only a marketing thing.
It is the code (ie: YY) that matters.
Old Mar 20, 2023 | 12:08 PM
OBS460's Avatar
OBS460
It matters if you walk in and say I need white paint for a 95 F-series vs. my truck is Colonial White. I care because whoever is helping you or working on the truck probably wasn't even born when it was manufactured and to them white does not contain any hint of yellow.
Old Mar 20, 2023 | 01:01 PM
McLeod's Avatar
McLeod
You: I need white paint for my 1995 Ford truck.
Paint store: What is the exterior color code shown on your data plate?
You: YY
Paint store: Okay. I will mix up the paint given the formulation shown by the manufacturer of the paint
Now, you are going to be screwed if your truck is currently not wearing its original color of paint.
The NAME of the paint is not as important as the CODE.
Old Mar 20, 2023 | 02:37 PM
yeet's Avatar
yeet
Thanks for the bumper pics. I really like it!
Old Mar 20, 2023 | 07:41 PM
McLeod's Avatar
McLeod
They sell em without the racks too. A bare bumper is $755 F.O.B. Arizona
They have 10% off going thru end of March.
Probably 60 day back order though
ashleyroachclip
15
Aug 11, 2020 07:10 PM
wanta65
Nov 22, 2015 04:02 PM
Tangmus
Paint & Bodywork
Jan 16, 2008 02:27 PM
stroken
Jan 10, 2008 02:55 PM
sdunham
Paint & Bodywork
Jul 29, 2003 11:29 PM
