compatible #2 Diesel?
Old Mar 17, 2023 | 07:16 PM
Nick 99's Avatar
Nick 99
Does anyone know what alternative fuel is compatible with our 7.3 ltr diesels? I live in San Diego and the gas stations are converting the tanks to renweable D2 fuels. I have bo idea as to what fuel will work for my truck. The regular D2 fuel is getting more dificult to find!
Help me out, Nick
Old Mar 17, 2023 | 10:23 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
"Renewable Diesel" is a California thing, and CARB regulations require that renewable diesel be used in off road equipment (backhoes, bulldozers, loaders, graders, skid steers, etc) by the beginning of next year. I have not seen regulations for renewable diesel for on-road highway vehicles yet.
I cannot speculate on whether, if , or how renewable diesel may or may not have any or no effect on the 7.3L diesel., but I am just as curious.
Old Mar 18, 2023 | 08:33 AM
Kwikkordead's Avatar
Kwikkordead
Isn't "renewable fuel" just a politically correct name for biodiesel?
Old Mar 18, 2023 | 08:41 AM
helifixer's Avatar
helifixer
Help me out, Nick
I have run B100 ( I make it) kerosene, Jet A, burned a lot of motor oil (new not used) transmission fluid (new not used) my cousin had a friend that worked at a high volume transmission shop and he burned all of their used transmission fluid.
as far as the re new able D2 I believe it meets the specs of regular diesel
Old Mar 18, 2023 | 11:12 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Renewable diesel is, or at least can be, better than biodiesel. They are similar, but not the same. The difference in the name is not political. Rather, it is to distinguish the variation in feedstock source, processing, blending requirements (or lack thereof), handling, transporting, and storage of these two distinct bio fuels.
The issue I have with renewables is the greater, and more importantly newer (fewer years in the field) variation in how renewable fuels are produced. Yes, the final result must meet an ASTDM standard for fuel oils, but most of us have lived through a few reversals brought about by the test of time.
Here are a couple of paragraphs from the EIA on the difference between renewable diesel and biodiesel. There is more to the differences than defined below, but I selected an excerpt from the EIA on purpose, to illustrate that even one of the most "politically correct" agencies in government (for energy source related climate change) still finds enough of a difference between renewable and biodiesel to describe their distinctions.
Originally Posted by Biofuels Explained
Renewable diesel is a biomass-based diesel fuel similar to biodiesel, but with important differences. Renewable diesel is a hydrocarbon that is chemically equivalent to petroleum diesel and can be used as a drop-in biofuel and can be transported in petroleum pipelines and sold at retail stations with or without blending with petroleum diesel. Renewable diesel production uses a hydrogenation process rather than the esterification process used to produce biodiesel. Because renewable diesel is a drop-in fuel, it meets ASTM D975 specification for petroleum diesel and can be seamlessly blended, transported, and even co-processed with petroleum diesel.
Most renewable diesel is hydrogenation-derived renewable diesel (HDRD) or hydroprocessed esters and fatty acids (HEFA) produced by hydrogenation of triglycerides, a similar process used for desulfurization of petroleum diesel. For this reason, existing petroleum refineries can be converted for renewable diesel production with only modest retrofits. However, hydrotreatment of renewable feedstocks requires significantly more hydrogen than desulfurization of diesel, and the source of the hydrogen could affect whether or not the renewable diesel can meet national or state standards for biofuels. Other methods can be used for renewable diesel production, such as gasification and pyrolysis. Renewable heating oil is similar to renewable diesel fuel but meets ASTM D396 for fuel oils.
Old Mar 18, 2023 | 02:12 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
It's a fancy name for subsidized.
Petroleum is renewable too as it's always being created....and not from dinosaurs, either.
Old Mar 18, 2023 | 02:14 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Just don't have a pistol brace in one hand and the fuel pump in the other hand... More than the Eeeeee Peeeeee Aaaaaye will come for your biscuits and gravy...
Old Mar 18, 2023 | 07:29 PM
Dan V's Avatar
Dan V
Aww dang...I like to burn dead dinosaurs.
Old Mar 18, 2023 | 08:56 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
The 7.3 will burn almost everything you put into the tank that is a fuel like substance, just stay away from the gas handle.
Pump it and burn it....Some however may be better with some fuel treatment.
Old Mar 19, 2023 | 12:56 AM
cln-nsty's Avatar
cln-nsty
I thought I read on this site that we were safe at a 10% Bio Mix. I believe it was something to do with the lubricating properties of the fuel. I've seen 20% Bio on some Indian Reservation fuel stations at great prices, just wasn't sure if it would harm injectors or HPFP. No harm , No foul. at the price of diesel in CA , it would be nice to know it's safe.
Old Mar 19, 2023 | 05:19 AM
Nick 99's Avatar
Nick 99
The biggest concern for me is that the effects on the injectors long term.
Old Mar 19, 2023 | 07:57 AM
Dan V's Avatar
Dan V
You can always add some type of lubricant. Some have used 2 cycle oil, some use Opti-Lube...others something else.
Old Mar 19, 2023 | 08:15 AM
bigb56's Avatar
bigb56
This came up awhile back and I posted a link to a lengthy discussion we had over at the Sprinter forum which I will provide again. In the discussion we had input from people in the industry both by email and phone, and one Zoom meeting with a refinery engineer. The general consensus is that the renewables are as good as or better than ULSD, and they meet the ASTM 975 specifications. Pump labeling is very confusing to say the least, and some of the labeling implies that it is a biodiesel when it in fact is not. (All ULSD has up to 5% biodiesel used as a lubricity additive and R99/R95 is no exception). If it says R95 or R99 on the pump it can contain up to 5% biodiesel just like the ULSD we are used to, but it will not contain over that amount even though some of the labeling implies 20%. We were told the labeling is a sore spot with the refineries because the EPA had a hand in it and the labeling was not what the manufacturers would have chosen themselves. One of the refinery engineers told us that the renewables are so refined that in their virgin state they have lower lubricity properties than ULSD so the addition of a lubricity package is very important, and many of us run an additive like Opti Lube just to "feel" safe although I can't confirm if this is really necessary. I suppose it would be good insurance if somehow the package got missed on a batch of R99/R95. Another thing we learned is that the reason R99/R95 is only available in CA, WA and OR is because they can't make enough of it yet to provide it in other states, they are maxed out right now just keeping up with those three states.
The Sprinter owners on the forum who live in these areas are now seeking out R99/R95 as their preferred fuel. It can and often is cheaper than ULSD in CA due to lower taxes on the renewables. We avoid B20 like the plague as it is not recommended in the Mercedes diesels with DPFs and can cause serious issues if used regularly due to buildup in the crankcase from regen post injections and fuel system clogging. (rumor is that the new 2l diesel will be compatible with biodiesel). Here is the link to the discussion: https://sprinter-source.com/forums/i...hreads/101841/
Old Mar 19, 2023 | 08:26 AM
bigb56's Avatar
bigb56
Another thing to note is that the engineers explained to us that the biodiesels of today are much better than the early biodiesels. If no ULSD or R95/R99 were available I would have no problem running B20 or even B99 in our dinosaurs but it would be a last resort in a DPF equipped diesel. We ran B100 in our old Mercedes 300D for many years. so some of the very early "primitive" production stuff. The only issue we had was in the Summer the loss of power while city driving was too much for us due to running the AC so in Summer we switched to B20. I also had to replace all my fuel line hoses with Viton.
Old Mar 19, 2023 | 08:38 AM
Kwikkordead
Nothing will ruin an engine design faster than when political agenda driven products get forced onto the market. They weren't satisfied with DPFs, now they want to push it even farther and foist a fuel online that will ruin that same DPF.
