351W engine build
I am in the process of an engine build (it's my first build so take it easy....) and looking for advice.
I have a 88 351W torn down and currently at the machine shop. Technician says block looks good and cylinders will get a .03 bore and block decked approx .01. Crank and rods also checked out good.
It's actually a marine application and a reverse rotation engine. The camshaft was hard to find so i had the stock cam re-ground to stock specs, hyd flat tappet.
For heads i am looking at edelbrok e-street aluminum heads, 60cc combustion chamber.
I'm looking at pistons now and need some advice. Obviously its not a high performance build, but i want to get the most without detonation issues. It will be run on 91 octane premium. Here are the piston options i am looking at.... any advice from the experts out there? Thanks in advance.
