2000 excursion
Old Dec 7, 2002 | 01:34 PM
jschira's Avatar
jschira
2000 excursion
Old Dec 10, 2002 | 11:51 AM
johnpaul's Avatar
johnpaul
2000 excursion
Can anyone tell me were to locate the trailer brake harness connection plug under the dash. I just purchase a 2000 X and need to hookup my electronic trailer brake.
Old Dec 10, 2002 | 01:56 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
2000 excursion
Remove the panel beneath the steering column. That's the panel to get to the fuse box.
The connector is towards the center of the truck, up high. It's a light grey 6 way connector. If you have the pigtail that came with the truck, it's the mate to that connector!
Old Dec 10, 2002 | 06:08 PM
moon dawg's Avatar
moon dawg
2000 excursion
I have an '01 and the connector is behind the fuse door (the one under the wheel with the screw-type latches in each corner) on the right side. My rig came with a plug/pigtail so if you have that, look for the corresponding connector. I hope that helps.
Old Dec 11, 2002 | 08:52 AM
johnpaul's Avatar
johnpaul
2000 excursion
Thank you everyone for your help, I found it right away
