Power Steering Pump Pulley Question
Old Mar 16, 2023 | 06:44 PM
NoakeaBean's Avatar
NoakeaBean
Hey everyone! I have a ‘79 f-150 with the 4.9 300 straight 6. I bent my power steering pump pulley trying to take it off and I need a new one. Is the pulley the same for all the motors of that era (302, 351, etc)? Thank you!!
Old Mar 17, 2023 | 06:23 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
So you must of used a 2 or 3 finger gear puller? And bent the outer edges. You know you have to use a actual p/s pump pulley puller. You can rent or borrow one from most auto parts stores that have a tool loaner program.
Yes I believe the 6 cly and the 302 p/s pump are the same. So do you have the p/s pump with the skinny metal fill neck (older style) or the one that the fill neck is made of plastic and is larger around? With a turn to lock on cap.
Old Mar 17, 2023 | 07:24 AM
Old Guy F-250's Avatar
Old Guy F-250
There is a thread on here somewhere answering this question. Actually Numbers Dummy had all the differences and numbers explained.
The PO of my 79 had a chrome pulley which was wrong. I believe the 300 pump pulley was a little different in someway BUT I had to end up at the JY and could only find a 80's something and it worked.
I always have a hard time tracking down old threads on here. Maybe some can revive it from wherever it is,,,LOL
Alex
Clifton Neal
Large Truck
Mar 9, 2023 06:16 AM
'78F250351m
16
Jul 11, 2011 02:51 PM
flowerlady
Sep 5, 2002 08:36 PM
