Carburetor
Old Mar 16, 2023 | 12:20 PM
Taube1994's Avatar
Taube1994
Trailering
Carburetor
I have a 427 side oiler I’m working on. I was curious what cfm carburetor it’s needs to run great? Any help would be appreciated
Old Mar 16, 2023 | 03:09 PM
85e150's Avatar
85e150
Depends on cam and intended use & single or dual carb.
750 to 1000 according to:
https://www.summitracing.com/newsand...cfm-calculator
Old Mar 16, 2023 | 06:43 PM
Thunderkiss1965's Avatar
Thunderkiss1965
On my 352 with a moderate cam, intake, headers, bumped up compression, I'm running a 650 and wouldn't want to go any bigger. So, unmless you are going really ***** out on your engine build a 750 or 800 CFM should be great. IMHO
Old Mar 16, 2023 | 10:03 PM
SwampRattFord's Avatar
SwampRattFord
Not a bad place to start.
https://www.holley.com/retailer/carbselector/
Old Mar 22, 2023 | 01:09 PM
Crop Duster's Avatar
Crop Duster
In my 69-muscle parts catalog Ford recommends a 780 Holley on all the single 4bbl manifolds the PN was C5AF-9510-BU. That said a 427 engine could handle a lot bigger carb than that. Since on the 2-4bbl manifolds they use two 780's. Good luck keeping that thing tuned up on the street.
Old Mar 22, 2023 | 01:52 PM
Taube1994's Avatar
Taube1994
Trailering
I’m rebuilding my dads ‘77 f250 and my grandpa put that motor in it. I can’t being myself to pull it and use anything else
Old Mar 22, 2023 | 02:24 PM
Crop Duster
Unless you plan on burning race gas. Pay attention to your static and dynamic compression. The stock ones were 11.1-1 mechanical cam and 10.9-1 Hyd. cam. Maybe your grandpa tuned it down a little when he put it in. The only 427 I spent much time in was in a 64 Galaxie and it was border line miserable to drive on the street. And that was when you could buy real gas.
Old Mar 22, 2023 | 02:31 PM
Taube1994's Avatar
Taube1994
Trailering
any suggestions on what to do to make more enjoyable?
Old Mar 23, 2023 | 04:04 AM
Crop Duster
I would say you first need to figure out exactly what you have. Find the casting numbers and date codes on the block and heads, manifold etc. Any history you can get from family. Remember the 427 was a low production engine and only sold in new vehicles from 1963-1968. But there were a bunch of them sold over the counter to racers though. The only detuned one that Ford put in production cars was the 68-hyd. cam version. And even it was a premium fuel engine. If it were mine and it turns out to be a complete unmolested 427, I would swap it for another engine that will burn the camel **** we have for gas now and turn it into money regardless of who put it there.
Old Mar 23, 2023 | 05:48 AM
hiball3985's Avatar
hiball3985
A 427 will have the COOL factor but what are you planning to do with it? If you are only driving it to the local car show so you can sit around with the hood up you may get away with it. If you plan on 200 mile trips you will ruin the engine or go broke buying racing fuel..
OldBlue68
Washington Chapter
May 22, 2008 09:20 PM
kwanderi
Mar 20, 2005 04:09 AM
Orange '63
May 4, 2004 08:38 AM
TheNomad
15
Jun 22, 2002 11:07 PM
