Front locking hubs replacement
Old Mar 14, 2023 | 07:53 AM
jimzpsd's Avatar
jimzpsd
Originally Posted by HeavyAssault
This is the "problem area" :
Anything on the inside of that orange O-ring is well protected. The outer side....well....yea it might need a little love to help prevent issues.
True, and this is where the problem stems...outside the o-ring and inside the plastic/aluminum actuator ****.
Old Mar 14, 2023 | 07:54 AM
jimzpsd's Avatar
jimzpsd
I found this video, but he doesn't show access to the **** assembly.
Old Mar 14, 2023 | 07:57 AM
jimzpsd's Avatar
jimzpsd
Originally Posted by morehouse7
Yeah, and looked at the corrosion and ignored it too like Arod.... I would take them apart at home and as said before FF them while they are new.
(and please send me your next replaced set for when I break one of mine)
I took them off this morning and will attempt to tear into them and clean/lube as needed. Not a fan of Arod myself.
Old Mar 14, 2023 | 09:22 AM
Reedog's Avatar
Reedog
I had the same problem on my old 2002 Super Duty. They were locked up and I broke the hub trying to free it. Not wanting to spend good money for a set of Ford replacement auto hubs, I eventually bought the Chinese auto hubs on ebay. They never actually worked in auto mode and I resigned myself to manually locking the hubs for the 6 remaining years I owned the truck. They required yearly disassembly to keep them freed up.
Old Mar 14, 2023 | 11:04 AM
jimzpsd's Avatar
jimzpsd
I have the hub pulled apart and it is definitely seized inside the **** to aluminum housing. Letting the penetrating oil soak as I try to figure out how to open up the **** housing.
Old Mar 14, 2023 | 11:12 AM
OBS460's Avatar
OBS460
Any of the all metal designs like the Warm Premium or the Mile Marker Premiums will last a long time with proper maintenance. If you use them that much I would just remove them once a year and grease them. They are simple to remove and if you use a waterproof grease like Schaeffer's EP 219 they should last a long time.
Old Mar 14, 2023 | 11:26 AM
DSLTRK60's Avatar
DSLTRK60
Originally Posted by jimzpsd
I've been adding lube periodically where the **** rotates in the metal housing since my first hubs got stiff. My third set,.... I'm done with OEM. However, if they are made by Warn, their hubs are supposed to have a life time warranty. Can someone post a link to the OEM Warn hubs on these trucks?
They are contracted by Ford from Warn, so the lifetime warranty is not applicable on the Ford Hubs, just the 5yr 60k mile factory warranty.
Even though they're expensive, the aftermarket Warn hubs use all 6 bolts instead of the three on the hub face, so they create a much better seal around the hub bore. Just FYI.
Old Mar 14, 2023 | 12:11 PM
jimzpsd's Avatar
jimzpsd
I'm finding the contamination is entering around the plastic **** itself from the outside, the guts (gears) are spotless and full of grease, but inside the aluminum flange (that mount it to the hub) is full of corrosion from road salt and the plastic dial is what is binding.
Old Mar 14, 2023 | 01:14 PM
SARDiverDan's Avatar
SARDiverDan
Many use their own brand when it comes to grease for these hubs. If you are the type that tries to stick with OEM, the manual calls for Motorcraft® High Temperature 4x4 Front Axle and Wheel Bearing Grease / XG-11 (WSS-M1C267-A1)
Old Mar 16, 2023 | 09:00 AM
DSLTRK60's Avatar
DSLTRK60
There's a warn premium hub set on eBay for 299 OBO. You might be able to get it for 200-250 if seller is wanting to move them.
These have a lifetime warranty.
https://www.ebay.com/itm/256011284865
Old Mar 16, 2023 | 11:12 AM
jimzpsd's Avatar
jimzpsd
I wonder how legit this is ...appears to be OEM but says "made in china" and notice the dial says FREE instead of AUTO
https://www.ebay.com/itm/37451149910....c101465.m3507
Old Mar 16, 2023 | 11:18 AM
jimzpsd's Avatar
jimzpsd
Thanks ........
Old Mar 16, 2023 | 11:19 AM
  #28
ToMang07's Avatar
ToMang07
Clearly chinese knockoffs. Even says "Unbranded" in the description.
Old Mar 16, 2023 | 11:44 AM
  #29
jimzpsd's Avatar
jimzpsd
LOL, I saw that too, odd how they can use Ford labels and get away with it.
Old Mar 16, 2023 | 12:07 PM
  #30
ToMang07's Avatar
ToMang07
China, much like Russia was decades ago, are ripoff kings. Russia would at least try to improve the designes and sell them as their own. chinese could care less, they will literally photocopy the directions from the people they ripoff and blurr out (usually....not always) the branding. There is A TON of counterfeit products on Amazon and Fleabay.
