Code 118 no continuity on harness
Old Mar 12, 2023 | 05:12 PM
Mickw's Avatar
Mickw
My truck is showing a code 118 high voltage for ECT. The wires to the harness are covered in black tape so i wanted to run continuity to test the wires to the PCM harness. I originally read the diagram wrong, i have continuity to pin 46, not not pin 7 as it should. Im assuming the wire is cracked, but what could cause it to run to 46?
Old Mar 12, 2023 | 05:52 PM
Prototypemech's Avatar
Prototypemech
Pin 46 is your 5v reference voltage. Pin 7 is the sensor return voltage (or resistance if you wanna think of it as that). Pin 46 should have continuity on one pin in the ECT connector. Pin 7 should have continuity on the other pin in the ECT connector.
Old Mar 12, 2023 | 06:04 PM
Mickw's Avatar
Mickw
Originally Posted by Prototypemech
Pin 46 is your 5v reference voltage. Pin 7 is the sensor return voltage (or resistance if you wanna think of it as that). Pin 46 should have continuity on one pin in the ECT connector. Pin 7 should have continuity on the one pin in the ECT connector.
goootcha, taking a look at the MAF, it has continuity from that same grey/red wire to 46 as well. Thank you for the input. The opposite wire still has zero cont. so Ill work on stripping that wire out and replacing it. 12 guage braided correct?
Old Mar 12, 2023 | 08:47 PM
Prototypemech
18 gauge, stranded. Yes. Pin 46 feeds 5v to about 6 different sensors, and then the sensors send a signal back to the ECU with a dedicated wire/pin. Pin 7 happens to be the one for the ECT sensor.
Old Mar 13, 2023 | 02:26 AM
Mickw's Avatar
Mickw
awesome, thank you very much
Bmitchell417
Nov 9, 2022 03:21 PM
PigFarmer
Dec 9, 2021 04:45 PM
cc35mki
Sep 27, 2012 08:22 PM
FourXFord2
1978 - 1996 Big Bronco
Feb 12, 2011 01:02 AM
ric37
Jan 3, 2005 03:04 PM
