dash and gauges
Old Mar 11, 2023 | 04:47 PM
jgun's Avatar
jgun
4wd High
dash and gauges
Hi I am new to this site and am rebuilding a 49 f1 with v8
need info on dash insert with gauges- am considering buying a new dolphin set up- will it work with current wiring?
should I keep looking for an old one??
thanks
Old Mar 11, 2023 | 04:57 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Stock sending units and gauges use a King-Seeley protocol. If straying from stock setup on either the gauges or the sending units, you must also do the other so it matches and they communicate appropriately. Non-stock setups will likely have different wiring requirements. Also, non-stock setups will most likely be for 12 volt negative ground installations, not the stock 6 volt positive ground.
To better direct you, it would be pertinent to know why you are seeking a dash replacement. Is it because the existing stock has faded/worn? Is it because a gauge or more is non-functional? Are you seeking a different look?
Old Mar 11, 2023 | 05:00 PM
abe's Avatar
abe
jgun, welcome to FTE the best Ford truck forum on the World wide Web!
I've got a 54 so I can't help you much but jmoran is spot on. Give us more info and others will be a long to help you too.
In the mean time show us pictures of the 49.
Old Mar 11, 2023 | 05:05 PM
jgun's Avatar
jgun
4wd High
the truck has NO dash gauges, all missing. all wiring from engine redone but still in 6V pos ground.
your comments are what I was worried about. I have looked on ebay for old inserts and found 1 but ideas on where else to look?
thanks
Old Mar 11, 2023 | 05:49 PM
bmoran4's Avatar
bmoran4
Your only real option is used/refurbished. eBay is a good source for used. You can then refurbish it yourself: https://myflatheadford.com/1948-1950...tion-kit-fail/
You can also use a rebuilder such as this: https://www.humphreyinstruments.com....board+Clusters
Beware - sometimes these clusters that are sold on the used market are done so because someone incorrectly hooked them up to 12V. This can cause damage the gauges necessitating replacement.
Old Mar 11, 2023 | 05:57 PM
gerrymoe's Avatar
gerrymoe
Dolphin Instruments | Flagler County | Dolphin Gauges
Classic Instruments Gauges | All Models Parts | Dash Components | Gauges - Aftermarket | Sets | Classic Industries
Might want to contact Dolphin Instruments to see what they can do for you. I have never worked with Dolphin before so I cannot offer up much. I have worked with Classic Instruments and they have a great tech dept and will pretty much do anything a customer wants
Old Mar 11, 2023 | 06:25 PM
bmoran4's Avatar
bmoran4
None of the Classic Industries or Dolphin offerings I've seen are drop in with the stock wiring setup. Going beyond that, most if not all of their aftermarket sending units will need mechanical and electrical adapters. This isn't saying those are necessarily BAD options, but you need to be aware that it isn't just drop in the dash and reuse everything else stock that is remaining. For what it is worth, all my trucks run stock clusters.
Old Mar 12, 2023 | 10:34 AM
bassdr's Avatar
bassdr
I switched to 12 v negative some time back. Then bought dolphins with new sending unit at the tank and they work fine and fit in place fine. I'm not experienced in keeping the 6 volt setup.
Old Mar 12, 2023 | 12:23 PM
jgun's Avatar
jgun
4wd High
thanks
I will check with Dophin but probably buy used original set up from ebay
here is my truck now
Old Mar 13, 2023 | 01:54 AM
Moe Craig's Avatar
Moe Craig
I've have a set of gauges I'm not going to use. Had them gone thru and all already. If your interested you can PM me for pics and we can work out a price.
Old Mar 15, 2023 | 08:19 PM
bmoran4's Avatar
bmoran4
Here is a recent thread on a refurbishment of a stock cluster: https://www.ford-trucks.com/forums/1...storation.html
Old Mar 24, 2023 | 12:07 PM
jgun's Avatar
jgun
4wd High
HI
I am not sure how best way to contact you directly is, but I would like to see your gauges that you could sell
thanks
Jeff
Old Mar 25, 2023 | 10:52 AM
gogoat's Avatar
gogoat
The original gauges are simple. Just follow each seperately. Hopefully you have a wiring diagram. Good luck and ask questions if needed. I have a 302/AOD with original gauges using correct senders, converted to 12 V neg ground with voltage reducer.
Old Mar 30, 2023 | 03:54 PM
jgun's Avatar
jgun
4wd High
wiring ameter
has anyone rewired the original dash gauge from a '49 F1
the rear of the ameter looks like the wire simply "passes through" from the starter to the circuit breakers- there are no connections on back of the ameter
Is this correct??
thanks
Old Mar 30, 2023 | 04:05 PM
bmoran4's Avatar
bmoran4
The wire simply passes through. This works because the current going through the wire induces a voltage in the encircling ring that then is used to move the amp gauge needle.
