ACM Upgrade
Old Mar 11, 2023 | 12:12 PM
Killer Volt's Avatar
Killer Volt
ACM Upgrade
Does anyone know if its possible to upgrade your ACM from 2017 to a 2020 or 2021 the pin connectors are different then the 2017-2019, I have both wire diagrams for pin out, the reason I'd like to upgrade is for the SDARS as my 2017 does not get all the XM channels the newer models get. Any information would be great.
Thanks
Old Mar 11, 2023 | 02:26 PM
Don Ridley's Avatar
Don Ridley
Along with the wiring changes, you would need to worry about the configuration file in the ACM. The new ACM may communicate with the 2017 but you will need to verify all of the settings will work in your vehicle. See the ACM asbuilt data in the F150 spreadsheet for the older and newer ACMs. There are some differences in the two ACMs.
Old Mar 11, 2023 | 03:22 PM
Killer Volt
Programing it with FORScan from Cyan Labs with the as builts for ACM shouldn't be a problem, I will check to see the differences as all the settings go, I did upgrade my APIM to a late model 3.4 ver with the latest build and firmware update. My concern is 2020+ has HS4 as well as HS3 just wondering if the ACM needs HS4 to communicate with the APIM.
4Kids
Electrical Systems/Wiring
Dec 21, 2022 09:56 PM
AFEGpilot1984
Nov 28, 2020 09:19 AM
1973FE
22
Apr 13, 2019 11:56 PM
Steve Lawrence
Oct 18, 2014 05:55 AM
jwdenney2
2004 - 2008 F150
Jan 19, 2009 07:36 PM
