General Automotive Discussion
Passenger Tires on 1997 F-250HD
Old Mar 9, 2023 | 01:49 PM
MadJax007's Avatar
MadJax007
4th Gear
Hey y’all, I went down to the local tire place and replaced my LT235/85/16 with 255/70/16. I traded some stuff for them a while back and did not notice the difference. Was going to use them because I just had them sitting around. I do not haul heady loads or tow, just use the truck as a daily driver work truck. Will I have any issues running on passenger tires? Thanks
Old Mar 9, 2023 | 04:33 PM
tjc transport's Avatar
tjc transport
i ain't rite
it depends on the manufacturer, type and load range of the tires. that size is also available in light truck rating.
Old Mar 9, 2023 | 04:50 PM
MadJax007's Avatar
MadJax007
4th Gear
They are ironman all country, listed as light truck tires.
Old Mar 9, 2023 | 07:12 PM
hobohilton's Avatar
hobohilton
Tires
1997 F250HD..
I did that swap with my truck. Same size just not the LT. Running then at a pressure slightly lower than the LT tires.
Truck rides better. I'm not hauling anything near the MAX GVW.
I noticed it took that sharp "shock" out of pot holes and other bumps that rattle your teeth.
Anything heavy and I load it on my trailer.
Old Mar 10, 2023 | 04:55 AM
tjc transport
i ain't rite
they are a 4 ply LT tire. a cheap all terrain tire.
that truck should have 10 ply load range "E" rubber on it.
Old Mar 10, 2023 | 06:13 PM
RLXXI's Avatar
RLXXI
No problems at all. Just beware you won't be able to safely carry your trucks rated load capacity with those tires installed. Driving unloaded your well within specs.
Synovia
Jul 26, 2022 06:56 AM
Soko179
Jun 24, 2022 08:21 AM
diesel2008
Dec 28, 2009 05:56 PM
paver1960
Sep 12, 2003 06:08 PM
gunz
Jan 12, 2003 11:10 PM
