Forscan "Easy Method" Cheatsheet.
I discovered that the spreadsheet descriptions are different than the "easy method" of programming in that they use different terminology. e.g - spreadsheet says "Temps on Gauges IPC 720-07-01", the verbose "easy method" says: "Digital Transmission Temperature Gauge" and "Digital Engine Temperature Gauge".
Maybe I am just slow - but it had me confused because I knew I changed it on my truck about month ago. But then I used the "Advanced Method".
Anyhow - I am wondering if anyone has a cheatsheet of the "easy method" descriptions and associated options. The options using the "easy method" for the 2 gauges were Disabled, Enabled (what I selected), Config 1 (which is the default), and Config 2 (no idea what this does).
