2019 superduty problems
Old Mar 8, 2023 | 10:28 AM
KIDkiser's Avatar
KIDkiser
Just got the truck back last week from having oil pans and front cover resealed for the 3rd time,transmission had to have a front seal put in als,all of this and the truck just has 32k on it.now 2days after I got it back and a couple hundred miles later the dash lit up like a Christmas tree.abs malfunction,traction service advantrac, and brake light.I shut the truck off for about 5 minutes and they went off.
ford pass says power train malfunction and antilock brake fault.so I took it to the dealer who done the work and they hooked it to the computer and they say the abs module needs to be replaced.does this sound right? They checked the plug at the back and it was dry and clean.since erasing the codes it hasn’t happened again.I’m at my wits end with this truck.
Old Mar 8, 2023 | 03:16 PM
greenno's Avatar
greenno
Bummer for sure having all those issues with a relatively newer truck.
I have a 2019 F350 XL edition CCLB SRW and have about 52k miles on it so far.
The horn I had to replace and a airbag plug broke off under the front drivers seat but that was covered under warranty pretty much.
There are some good ones out there.
Old Mar 8, 2023 | 03:48 PM
cpobst's Avatar
cpobst
I hope you didn't use the same dealer for all 3 reseals?
Old Mar 8, 2023 | 04:12 PM
KIDkiser's Avatar
KIDkiser
Originally Posted by cpobst;[url=tel:20770093
20770093[/url]]I hope you didn't use the same dealer for all 3 reseals?
unfortunately I have since the dealership is only 8 minutes from my house.the mechanic said he’s never had this much of a problem getting the pans to seal.
Old Mar 9, 2023 | 08:16 AM
mattymax's Avatar
mattymax
Yea probably because he’s never done it before. I would have switched dealers after the first l failed attempt
Old Mar 9, 2023 | 09:39 AM
austinb1017's Avatar
austinb1017
Tripped 177,000 on mine this morning. Nothing but brakes and maintenance.
Allisguy
Sep 7, 2023 12:22 PM
Bute56
Feb 4, 2023 10:34 PM
heathrunkles
15
Jun 20, 2009 10:41 PM
ptt
1997 - 2003 F150
Dec 24, 2008 05:46 PM
