Camera randomly stopped
Old Mar 6, 2023 | 11:59 PM
18powerstroke's Avatar
18powerstroke
7th Gear
Hi There,
So currently I've been having camera issues on my 2018 ford f350 xl this is the factory camera that came with the truck I've had an after market alpine ilx-w650 since the first month i owned the truck due to no bluetooth for some reason last week i had the camera flashing on and off then it completely died using bluedriver i got the code b115E-08
what i have done to the truck so far looking into this problem
  • cleaned all connections
  • bypassed ground to a clean metal piece on the truck
  • replaced camera
  • cleared the code
The truck switches the radio to camera mode but no images show up and im out of ideas
Old Mar 7, 2023 | 08:21 AM
morehouse7's Avatar
morehouse7
Get Forscan and try the camera recalibration function.
Old Mar 7, 2023 | 01:51 PM
RapidRed7.3's Avatar
RapidRed7.3
Originally Posted by 18powerstroke
Hi There,
  • replaced camera
  • cleared the code
I know I've had to actually partially dissemble the connector by the spare tire to resolve a issue I was having. The corrosion was actually between the pins on the female side. Depending on how thoroughly you cleaned, it may be worth your time to take the white pin locator cover off and check for corrosion inside the plug.
rjr6/150
6.7L Power Stroke Diesel
Nov 10, 2021 06:34 PM
99PREDATOR
Jul 22, 2011 11:23 PM
BoneSS
2004 - 2008 F150
Nov 24, 2007 01:46 PM
Born2DriveFords
General Automotive Discussion
Aug 17, 2007 08:48 PM
owlman
Jun 2, 2004 07:09 AM
