Throwing code P0402
Old Nov 9, 2021 | 03:53 PM
rjr6/150's Avatar
rjr6/150
Trailering
Throwing code P0402
Driving yesterday CEL came on. Stopped by the local dealership they ran a quick scan came back as you will see below.
Any ideas?
Vehicle is 2016 F350 6.7
Appreciate the assistance
Randy
File Type: pdf
Old Nov 9, 2021 | 06:28 PM
Fefanatic's Avatar
Fefanatic
Most likely the flow sensor is bad. Did they clear the code? Did it come back?
Old Nov 9, 2021 | 07:45 PM
rjr6/150's Avatar
rjr6/150
Trailering
Not yet drove it home from dealer approximately one mile.
Old Nov 10, 2021 | 06:34 PM
Fefanatic's Avatar
Fefanatic
Codes help but you need them to look at the data. I have a Forscan package and a laptop computer to run it on. Do the search for FORSCAN and the OBDII adapter and get yourself set up with that. FORSCAN has a free version that works great and a OBD adapter should be around $30.00. You can scan the truck yourself and look at the data. It will also help you with further problems down the road.
brandon tracey
Jul 30, 2017 07:04 PM
F350SD
6.7L Power Stroke Diesel
Oct 3, 2016 10:13 PM
olds&fords
Aug 22, 2014 10:52 AM
cool guy
2004 - 2008 F150
Aug 5, 2006 12:02 AM
