My recent purchase.
Old Mar 6, 2023 | 09:50 PM
flatwoods1's Avatar
flatwoods1
3rd Gear
My recent purchase.
My new to me 95 f350 with 120k miles. I have looked for a long time for one of these trucks and finally found one. It has been garage kept for the last 20+ years
Old Mar 6, 2023 | 10:27 PM
z31freakify's Avatar
z31freakify
Great looking truck, welcome aboard.
Old Mar 7, 2023 | 08:29 AM
knottyrope's Avatar
knottyrope
nice find, i have a thing for 95s
do you have orange boot of death on turbo inlet?
Welcome aboard!
https://www.ford-trucks.com/forums/1...sel-truck.html
Old Mar 7, 2023 | 09:26 PM
flatwoods1's Avatar
flatwoods1
3rd Gear
Welcome aboard!
Yes but will be changed very soon.
Old Mar 9, 2023 | 10:52 PM
510galaxy's Avatar
510galaxy
Nice looking truck! Welcome.
Old Mar 10, 2023 | 06:47 AM
Yeoman's Avatar
Yeoman
Thumbs up Nice truck!
What are your plans ? Work? Restoration?
There is a lot you should do before use.
Just because it was garaged doesn't mean it didn't deteriorate.
Get the dead bugs off the paint; the chemicals emitted from deteriorating bugs and bird droppings stain and damage the finish.
Pay really close attention to the undercarriage where moisture from the floor (even concrete) causes rust on the frame and floor (cab and bed).
Lack of use results in accumulating rust in difficult to access places. Unlike easy to see areas, these places, once exposed to water (with or without salt) begin to rust quickly (unless of course you live in a desert).
For example, simple things like changing the fuel filter can lead to a big job. The seals in the fuel bowl have likely hardened due to age, not worn due to use. Opening the drain valve might result in a constant fuel valve leak, for example. Sitting still does a number on spring bushing, shocks and brakes. Get yourself a bore scope and look in places for rust and debris like inside the tailgate, the rear wheel well between the outside fender wall and the inner spatter shield; the underside of the rear fuel tank, inner door and front fender panels. These place are where an once of prevention is work a pound for cure.
The truck is very much worth the effort and cost to systematically go through everything. Not a five minute task but one that will give you many years of enjoyment if done well.
Good luck with it.
Old Mar 10, 2023 | 12:53 PM
Hit Man X's Avatar
Hit Man X
Swap that master cylinder pressure switch too.
Old Feb 24, 2026 | 09:16 PM
flatwoods1's Avatar
flatwoods1
3rd Gear
I have had this truck for 3 years and I have made a few changes to it after some needed maintenance. It had a major boost leak at the collector on the back of the turbo. The up pipes were replaced and the EBPV was deleted thanks to Riff Raff. While I was in there I did a fuel bowl delete and a CNC Fab 4 Line feed and a Marty's E fuel kit along with a 38 gallon rear tank. I had a cheap Dana 60 fall into my lap so I couldn't pass it up. This is how it sits now.
Old Feb 26, 2026 | 05:39 PM
97-psd's Avatar
97-psd
You guys with your dually Crewcab 4wds. I love ‘em
Old Feb 26, 2026 | 05:41 PM
Hit Man X's Avatar
Hit Man X
Hey mine is also a dog dick red dually. But extended cab and bucket seats ...also a ZF
Yet has dork mirrors
CTYankee
Massachusetts Chapter
Mar 3, 2021 04:07 PM
Tom Wenskaug
Jun 30, 2019 09:01 AM
Tilleyman
Nov 7, 2016 10:32 PM
drivesprocket
Sep 9, 2016 09:15 AM
bryanswens
Vehicles for Sale
Jul 2, 2011 08:34 AM
