Sponsored by: Real Truck
OEM U-Joints
Old Mar 5, 2023 | 10:30 AM
PJWhelan's Avatar
PJWhelan
OEM U-Joints
Hello,
Does anyone know what U-joints are installed at the factory? Sealed or greasable?? I was just checking my front end (2002 F-250) and looking at the axle u-joints and one side is sealed, one is greaseable. My drive shaft on this Crew Cab 4WD, was greaseable U-joints. So, I had to replace my front driveline and so I ordered sealed U-joints. I can't ever remember actually greasing any of these up and I am the original owner. I am going to redo the front end in the near months (new seals, new u-joints on the axles, new wheel bearing, new shocks, that kind of rebuild). For this rebuild it'll be sealed U-joints, because well, the truck is 21 years old)
Old Mar 5, 2023 | 06:04 PM
WWR's Avatar
WWR
I've never seen a greaseable joint used by OEMs on domestic trucks. Unless you're hardcore about greasing them and/or specific applications like being regularly submerged, greaseables are junk.
Old Mar 6, 2023 | 08:23 AM
99powerstrokedF250's Avatar
99powerstrokedF250
I wouldn't say greaseables are junk, but I will agree that you need to be religious about greasing them. You also usually need special grease gun tips to be able to grease them, as a standard gun nozzle won't fit up in there in most cases.
I have had greaseable AND sealed ones last 60k+ miles, and I've also had them both last less than 5k miles. It's usually more about how you install them and how you care for them (oh and making sure they're a good quality unit) than anything.
Old Mar 6, 2023 | 08:30 AM
WWR's Avatar
WWR
Old Mar 6, 2023 | 10:10 AM
hobohilton's Avatar
hobohilton
I have several pieces of "vintage"equipment here on the homestead.
I will always go with U Joints, Ball joints, Bush hog drive shafts and lawn mower decks with grease fittings.
On a sealed bearing fine particles of dust will migrate into the bearing. Having a grease fitting allows me to flush out both dust and metal as the bearing wears.
Recently I removed U Joints from my truck while replacing clutch / transmission. I found Ford OEM U Joints with 3 of the 4 bearings greased and one that appeared to never have had grease in it.
But again, I prefer manual window cranks to electric windows.
Hobo
Old Mar 6, 2023 | 03:27 PM
WWR's Avatar
WWR
I've had numerous OEM joints go 200k miles. On our '02 Silverado I finally replaced at 208 just because it seemed proactive. I should have left them, they were fine.
Now I don't touch OEM u-joints unless I have legitimate reason to know they're bad. I maintain a small fleet all between 150k to 230k and I'd say 95% are on the factory u-joints.
I did have an OEM go bad on my '05 Canyon at 40k.
200k or more and never having to worry or pull out a grease gun....that's a choice I'll make every time.
Axle shaft (at the knuckles) joints are different. They seem to fail much more often.
Old Mar 6, 2023 | 08:57 PM
apache84's Avatar
apache84
Personally id use nothing but Dana/Spicer U joints. I use Dennys drive shaft in NY. Good prices and fast ****ting. I used Precision once and their not worth the effort IMO.
Jeff64F100CrewCab
Jul 12, 2015 10:48 PM
the_auto_tech
Dec 3, 2013 04:13 AM
oricle
Jun 10, 2005 07:03 AM
waynejohn
Sep 24, 2004 08:01 PM
comic75
Apr 28, 2003 10:16 AM
