Oops - wrong oil.
Old Mar 4, 2023 | 12:59 PM
Slowthump's Avatar
Slowthump
Oops - wrong oil.
So a guy was changing the oil in his 7.3 gas and realized he had put 5w20 instead of 5w30 in the engine at the last oil change 3,000 miles ago. I wouldn’t think this to be too big a deal especially during the winter in northern Minnesota. However, I’ve heard that this engine utilizes a variable pressure oil pump. Hope it wasn’t too bad for the engine. What do guys think? Asking for a friend.
Old Mar 4, 2023 | 02:08 PM
senix's Avatar
senix
just change it, doubt there is too much to worry about given the colder temps.
Lets just hope he wasn't towing with it.
Old Mar 4, 2023 | 02:36 PM
Pbergmann's Avatar
Pbergmann
Yea... I knew a 'friend' like that. Wore the same clothes as me and had the same wife.🫣🤔
Old Mar 4, 2023 | 07:05 PM
ShotgunZ71's Avatar
ShotgunZ71
Completely fine. He can run it until the next scheduled service with no worries.
Old Mar 4, 2023 | 08:46 PM
KU4OJ's Avatar
KU4OJ
I was under the impression folks were doing that to get a bump in fuel mileage. My 5.4 Triton called for 5w20 so it can't be all that bad, can it?
Old Mar 4, 2023 | 09:00 PM
offacough's Avatar
offacough
Manufacturers are under extreme pressure to meet CAFE fleet standards, which continue to get tougher. While I think our Super Dutys are exempt, there has been a push to use these thinner oils as part of numerous small steps to squeeze 1mpg extra.
I’m not a fan of those oils except under extreme cold, low load conditions. Many manufacturers who used to say 5w20 have switched back to 5w30.
I think the gentleman who is the topic of this post is fine, however.
Old Mar 5, 2023 | 07:26 AM
scraprat's Avatar
scraprat
Top Answer: 5
Good point about 5w20. I wouldn't sweat it either having that oil in it. Just change it out at at your normal interval.
A quick read to give an idea.
https://blog.amsoil.com/5w-20-vs-5w-...he-difference/
Old Mar 5, 2023 | 10:46 AM
HRTKD's Avatar
HRTKD
There has been at least one manufacturer that originally called for 5w-20 then switched to a higher viscosity oil when issues came up.
As stated earlier in the thread, during the winter I wouldn't worry too much about it. But I would shorten the oil change interval.
Old Mar 5, 2023 | 10:59 AM
scraprat's Avatar
scraprat
Top Answer: 5
The Ford 5.4, 6.8 & 6.2 used 5w20 oil in all conditions. 5000 -7000 mile oil changes with 212k to 275k miles on engines.
Old Mar 5, 2023 | 11:14 AM
morehouse7's Avatar
morehouse7
I think it's fine and wouldn't worry at all, but I wouldn't tell the dealer if you go in for engine warranty work, those clowns might deny a claim like roller delamination.
Old Mar 5, 2023 | 11:33 AM
OverheadCram's Avatar
OverheadCram
Ford had publications out when they first switched the Modular OHC engines from 5w-30 to 5w-20 for the North American (U.S. and Canada) market. They explained why they made the change (CAFE) and that the 5w-20 still met their standards for use in the Modular OHC engines. The rest of the markets the Modular engines were sold in still specified 5w-30 oil. Ford even changed the engines back to 5w-30 (6.8L, 6.2L, 5.4L, and 4.6L) once they were only fitted in vehicles that didn't need to meet CAFE standards anymore.
The 7.3L though is not a Modular engine and there is no testing at least made public that verifies 5w-20 meets the 7.3L standard. What it is doing or not doing in the 7.3L engine is a wild guess at this point.
Old Mar 5, 2023 | 11:41 AM
scraprat's Avatar
scraprat
Top Answer: 5
I vaguely remember thread/ posts from the past of guys using 5w30 even though 5w20 was being speced, 5w20 was too thin for their liking and the engine wouldn't live a full life and have early catastrophic failures. Which wasn't the case.
Old Mar 5, 2023 | 07:32 PM
aklim's Avatar
aklim
You know, that is a coincidence. I have had a "friend" like that. Only difference between us is he does silly things and I don't.
Old Mar 5, 2023 | 07:34 PM
aklim's Avatar
aklim
Let’s look at 5W-20 vs 5W-30 again. The 5W-20 will remain a little thinner at operating temperature, as indicated by its lower “20” number, while 5W-30 will provide a slightly thicker lubricating film.
Oil isn't that expensive. I'd just change it for peace of mind and be done with it.
Old Mar 6, 2023 | 08:16 AM
speedfreak78's Avatar
speedfreak78
Modern synthetics and blends are are so thin to begin with, the difference between a 5-20 and 5-30 is almost impossible to tell. And with the highly advanced additives packages they perform almost identically, except at the higher temp extremes. Not like old conventional oil when you could see the difference in flow between the 2 and feel a difference in the way an engine ran. If it's that much of concern to you a dump and refill isn't really a huge cost.
