If I am understanding this right, I think I have a 6R100 (how do I tell if its a 6R100 or 6R140?) trans in my 6.2L gasser 2017 F250, which may have the heated fluid requirement before it sends more than 10% fluid to the cooler ,( meaning I need to do the cold flush from video in this thread.) right??
whats confusing me I guess is,
There is another YT video of a guy doing 6R140( 6.7L truck) from the cooler output that looks easier than this cold fluid flush here, but sounds like this thread states he should have been only getting 10% flow with cold fluid. Right?
with the 10% cooler output cold fluid flush, wouldn't I need like 40 quarts through it before it came out bright red clear fresh fluid at the 10% flow?
or am I way off? and no heated fluid needed on my trans, so no need to do this threads cold flush and won't be wasting tons of fluid out the cooler output?
You have the 6R100 transmission. F350 or diesel gets the 6R140 that year.
thanks that's what I thought but couldn't find anything to tell me it was... now I have to figure out if cooler output fluid change or the cold flush like the vid I found in the previous gen forum and they moved my post back here.
if there was ever a time to get a service manual its now. you sound lost. very lost
not lost, just details or questions that pop up. And like I mentioned, this was in the previous gen forum the cold flush video was... it was edited/ reworded... and moved here by a moderator... so it doesn't track very well here... I posted it there because I would just have to link everyone here to that thread anyway... some mod changed it and moved it...
do you know if this trans has the thermostatic control to the cooler? Can you look it up in your service manual?????
been a ford guy since mid 80's and my folks had fords... biggest thing I learned was early maint. Is the trick.. I would never wait 100000+ to change trans fluid. I have already done plugs and cleaned crust out of coils( misfire codes) and coolant and thermostat. Brake fluid is original and dark so that's next. And early trans flush is way cheaper than a trans replacement.
