Rear Frame
Old Mar 1, 2023 | 10:39 AM
Lodgestone's Avatar
Lodgestone
2nd Gear
Rear Frame
I have a 2001 ford ranger Edge 4.0L 4X4 . The rear section of the frame is rotted out and I have a line on a 1997 Mazda B4000, will it's frame work?
Old Mar 3, 2023 | 09:25 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
The rear section would be the same if that is what you plan to swap. The front 2/3 of the frame is completely different. The spare tire carrier would be a swing up on the 97.
Old Mar 3, 2023 | 09:37 AM
tommyleea's Avatar
tommyleea
Are you sure it is the frame that is rotted? I have an 01 ranger, and my rear spring support brackets were rusted through. I thought it was the frame at first, but on further inspection it was just the brackets. If it is just the brackets, they have repair kits for this problem. New brackets, shackles, spacers, bolts, bushings, and even the springs aren't that expensive if you choose to replace. Once I removed the old rusted bracket, it turned out my frame was just fine. Evidently a common problem.
Old Mar 3, 2023 | 06:30 PM
Lodgestone's Avatar
Lodgestone
2nd Gear
Thanks for the reply. Yes, the whole rear frame is rotted out. Holes you can stick a finger through and Monday, the frame cracked right over the driver's side back tire. It's done, lol.
Old Mar 4, 2023 | 11:27 AM
Hank85713's Avatar
Hank85713
Look at youtube there is a guy there who just R&Rd a frame such as you are asking. He has a 4cyl 2.3 with 5sp manual, with 4 wheel. He got a donor truck sliced the frame and reassembled:
https://www.youtube.com/results?sear...ut+and+install watch the 1st videos on how he did this.
This is a different vehicle.
Old Mar 6, 2023 | 09:05 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Hello fellow Missourian, yes please make sure and stop by the FTE Missouri state chapter forum and get
signed up.
Missouri chapter forum thread list. https://www.ford-trucks.com/forums/forum104/
Click this link to get to the chapter member sign up link.
https://www.ford-trucks.com/forums/5...ml#post4083744
Feb thread
https://www.ford-trucks.com/forums/1...n-in-yall.html
March thread
https://www.ford-trucks.com/forums/1...ory-month.html
Rich 77&79F250
ryans88gt
37
Dec 23, 2013 05:24 PM
mjshagnasty
Feb 9, 2011 07:28 AM
fergusonicford
Nov 24, 2006 06:12 AM
gdavis2265
Jun 4, 2003 11:13 AM
STEVE1103
Mar 10, 2002 11:02 AM
