Windshield leaking??
Old Mar 23, 2023 | 10:31 AM
Greaser007's Avatar
Greaser007
I have a hunch your leak may be fixed if the windshield glass was resealed after removal of old sealer. Time will tell.
I paid our local glass shop to remove my trim pieces, and my E250 only had light surface rust in a few places and mostly at the bottom of the pillars where water can sit because of build up of debris which sits underneath the trim, unless pressure washed out often.
I masked off and carefully sandblasted the portion of the pillars that is covered by the trim. Then liberally brushed on black Rustoleum as a base.
One month later I fired up my small dash paint gun and painted the pillars. Now I'm waiting for winter to pass so I can paint the roof, and have my windshield moulding trim re-installed.
Please let us know the outcome of the re-sealing and if you still have a leak.
Old Mar 23, 2023 | 10:38 AM
Mike1's Avatar
Mike1
So far it's just been sitting in my driveway and no leaking, I'll get it out this weekend and drive it to see if and water comes through. I also plan on pulling the pillar trim inside to check out the rust situation and do the same as you with sand blasting but I may use a POR in there instead of rustolium, I don't know yet....I'll let ya know what's happening.
CyberEric
Nov 15, 2021 06:03 AM
GliderGirl
Feb 15, 2017 06:46 PM
Lost Yankee
Jan 13, 2014 01:45 AM
2tone73
Oct 7, 2005 05:53 AM
jkorreck
Aerostar
May 10, 2004 06:07 PM
