ok i found it a 1960 352 with a 2 barrell had 220 hp at 4300 rpm and 336 fpt at 2600 rpm, bore 4.0, stroke 3.5, compression 8.9 to 1, a 1960 352 with a 4 barrel had 300hp at 4600rpm and 381fpt at 2800 rpms, any other year u want i can find to.
The 352 was first available in the trucks in 1965 (then through 67), before that they had the 292's. 352's were available in passenger cars from 1958, if I remember correctly they were the "X" code. These put out bigger numbers and were along the same lines as the "PI" version of old....
Someone correct me if need be, it's a little dusty back in the cave
