Embarrassing question: What Gas? (87/e85)?
Old Feb 25, 2023 | 03:48 PM
ameri180304's Avatar
ameri180304
2nd Gear
Arrow Embarrassing question: What Gas? (87/e85)?
So I've owned 4-5 F250's at this point, always been a diesel guy. Last night I got a 2021 F-250, gas engine (6.2). I read through the owners manual, it was going on about "E85" (I'm in california if this matters). The cap on my tank is yellow. So when I open up gas buddy and search "e85", this gas is going for $2.99/gal. Yet, 85-87 is going for $4.89+. I guess my question is, can my truck use either or? If I could use the e85, should I?
Old Feb 25, 2023 | 04:09 PM
2008f250xlt's Avatar
2008f250xlt
You can use either. E85 gas mileage will suffer.
Old Feb 25, 2023 | 04:11 PM
4wd6.7L's Avatar
4wd6.7L
I have never owned anything that runs on e85 but here is a thread talking about it. https://www.ford-trucks.com/forums/1...-fuel-e85.html
Old Feb 25, 2023 | 04:13 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I wouldn't use E85, but at almost $2 difference, I'd probably think about it...
Old Feb 25, 2023 | 04:34 PM
ameri180304
2nd Gear
Yeah I googled it shortly after posting this. I guess the truck would suffer, and it possibly causes problems down the road. I suppose I'll just be grateful to have gas at -$1 less per gallon lol, and just stick with that.
Old Feb 25, 2023 | 05:53 PM
Joe T's Avatar
Joe T
It won’t hurt it and mine ran a little better on it at really high miles though. I used when towing a lot so I didn’t have to run mid grade gas.
Supposedly you loose 10-20% efficiency.
Old Feb 25, 2023 | 06:02 PM
fordman19762003's Avatar
fordman19762003
The manual used to say that if E85 was used most of the time that you needed to run a tank or two of regular gas through every few thousand miles. I know with an old F150 we had E85 needed to be at least $.50/gallon cheaper just to break even because of the mileage loss. that was in 2007 though so maybe the trucks are more efficient with E85 now.
Old Feb 25, 2023 | 07:15 PM
KU4OJ's Avatar
KU4OJ
You might want to run 2 tanks of E85 and then one of 87. That should keep the fuel system happy. Real gasoline contains additives that are good for the rubber parts of the fuel system. I wish the 7.3 were Flex Fuel, it would perform better on the 10% ethanol blend we use here and it would be somewhat future proof.
Old Feb 25, 2023 | 07:58 PM
Mirage Flatter's Avatar
Mirage Flatter
In my opinion, there should be zero concerns with using E85 in a flex fuel vehicle, otherwise why would they be designated as flex fuel vehicles? And while I didn’t run any numbers, I believe your gas mileage would have to suffer pretty significantly before the advantage wouldn’t pencil out when there’s $2.00/gallon difference in price. We have a 2011 Mercury Milan which is flex fuel capable. I tried E85 in it once, and the gas mileage did suffer, but I believe that at the time there was only a $.50/gallon difference in price, it wouldn’t pencil, and I’ve never tried it again. That was on a trip, and E85 isn’t available where we live, so it’s pretty much a non issue. But if I had regular, everyday access to it at a $2.00/gallon discount, I’d darn sure be running an experiment with it at least.
Old Feb 26, 2023 | 02:04 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
The 7.3L is perfectly designed for 10% ethanol. Any of these trucks perform just as designed on 10% ethanol fuel, because that is what is available at 99% of gas stations across the country. A Flex Fuel engine just means it's capable of using 85% ethanol blend fuel.
Old Feb 26, 2023 | 09:22 AM
Joe T's Avatar
Joe T
So contrary to what anyone says or the manual I would stick with whatever you are running.
Getting in the low teens mpg is normal for these trucks. I wouldn’t sweat loosing 1-2mpg.
$4.89 at 12mpg is 8.33 gallons burned every 100 miles. For $40.73
$2.99 at 10mpg is 10 gallons burned every 100 miles. For $29.99.
Saves about $160 a month if you drive 1500 miles a month.
20% may be overly pessimistic because I do not remember a change that drastic or a change at all. It always stayed at 10.X mpg. That 20% would be your worst case scenario.
If you need to run some gas through it make sure its empty and vice versa.
Old Feb 26, 2023 | 10:34 AM
Leardriver's Avatar
Leardriver
I run a 30% mix of E85 and 91 octane in my BMW turbo cars, and it is magic sauce for huge HP . Street driven normally aspirated won't get much benefit, and gas mileage will be down 20%, negating some of the cost savings.
Old Feb 26, 2023 | 10:57 AM
OverheadCram's Avatar
OverheadCram
At that price difference the % saved vs the % of mileage loss is a no brainer. Use the E85 as directed in the owners manual.
Old Feb 26, 2023 | 07:37 PM
2004Limited's Avatar
2004Limited
Joe,
You did an awesome job of simplifying the math with your example!
You must be a teacher?
Old Feb 27, 2023 | 06:05 AM
Joe T's Avatar
Joe T
Oh thanks! No I just pass some time by posting on some forums I have hobbies in, I dont have cable tv so I get some spare time.
I do run some construction crews so maybe that has taught me how to lay out clear communication.
