Door panels
Old Feb 23, 2023 | 06:21 PM
bigboyhighboy's Avatar
bigboyhighboy
Door panels
I am replacing the door panels on the interior of my 1975 highboy truck. I was just going to get black ones and paint them to match the originals as I can not find ones that match the factory color. How would you go about color matching the originals and then painting the new ones? Thanks
Old Feb 23, 2023 | 06:31 PM
440 sixpack's Avatar
440 sixpack
What color ?
If you can't find the color you want in a quality vinyl paint somewhere you can go to your PPG or BASF paint distributor and they'll custom mix you some. it would be better and cheaper to get colored ones if you could though.
Old Feb 23, 2023 | 06:36 PM
bigboyhighboy
It’s a darkish green color. I have not seen any trucks with the same color. Would you have any ideas on who might sell a pre colored one that is green?
Old Feb 23, 2023 | 07:17 PM
440 sixpack
I don't, it's been discussed here and I think they're unobtainium.
some guys convert to black, some do like you're talking and vinyl paint them. someone here might chime in with a better idea but green is a tough one.
Old Feb 23, 2023 | 07:28 PM
bigboyhighboy
Thanks. Is painting a good option or does it not look and last well? I’m worried it will look aged fast
Old Feb 23, 2023 | 07:49 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 on any thing green color and interior is hard or next to impossible to locate in a repop. But used and reusable is about you only option, unless you get new repop and paint them. SEM has a great reputation as far as interior plastic paint. https://www.semproducts.com/products...pholstery-trim
Going with a partial interior color change to black door panels might be the best route.
https://www.dennis-carpenter.com/tru...ck-no-arm-rest
Old Feb 23, 2023 | 07:56 PM
bigboyhighboy
So paint won’t look as good as an actual colored one? Will it perform the same?
Old Feb 23, 2023 | 08:01 PM
77&79F250's Avatar
77&79F250
Yes a painted will not look as good as actual molded color one or wear as well either.
Seen these? https://www.carparts.com/details/For...B&gclsrc=aw.ds
Ebay ones. NOT mine. https://www.ebay.com/itm/175043470617
And https://www.ebay.com/itm/12578042865...1HwwKCprXVVyFY
Old Feb 23, 2023 | 08:16 PM
bigboyhighboy
Maybe I should trying repairing my old ones. Would you guys know how to repair small cracks and broken tabs that attach it to the back of the door?
Old Feb 23, 2023 | 08:38 PM
77&79F250's Avatar
77&79F250
Repair from the back side with JB weld plastic epoxy, common 2 part epoxy. Or....you can easily fix it with Threebond Plastic Repair Kit. It's mostly used by motorcycle guys for repairing cracked fairings, but it works great on door panels. It has super glue and fiberglass cloth and makes the repaired area stronger than new.
The 2 notches are to let the door panel clear the 2 bolt heads on the L shaped metal bracket. The arm rest covers the notches. Get METAL finger cups from LMC. https://www.lmctruck.com/1973-79-for...handle-cup-set I made some sheet metal reinforcement pieces.
Ditch the metal mount pieces and get the plastic Xmas trees. GM are longer and have a bigger head.
Old Feb 23, 2023 | 08:48 PM
bigboyhighboy
I will give it a try. Thanks for all the help
Old Feb 23, 2023 | 10:07 PM
LandAndStone's Avatar
LandAndStone
Desk Jockey
This is what you need. Perfect match.
Contact Vinyl Pro. Color code shown.
Here is how mine turned out. Those are black DC panels under there.
Old Feb 24, 2023 | 09:09 AM
Old Guy F-250's Avatar
Old Guy F-250
X2 X2 on the SEM paint.
Little $$$$ pricey but great vinyl paint.
Mine were in bad shape actually had them in the discard pile UNTIL I could not find any in JY better than mine.
Used 500 paper, sanded it down a little, then wiped down with the oil, grease cleaner.
Next day painted with the SEM and looked good.
Actually the discoloring by the handle is a reflection
Actually, that discolor by the handle is a reflection!!!!!
Old Feb 24, 2023 | 09:36 AM
ivsamhain's Avatar
ivsamhain
local shop mix the color for you? I’ve bought 2 different browns that I’m not going to be happy with
Edit: I found vinyl pro… https://www.vinylpro.com/custom-colors/
Old Feb 24, 2023 | 12:57 PM
bigboyhighboy
That seems to dark for my green. My green is lighter
