ZF6 QUESTION
Old Feb 23, 2023 | 05:39 PM
Dericksuperduty's Avatar
Dericksuperduty
Trailering
ZF6 QUESTION
SO I INSTALLED AND USED ZF6 AND NEW CLUTCH. WHEN ITS IN NEAUTRAL IT AINT IN NEAUTRAL AND CLUCH ALSO DOESNT DISENGAGE
.ANY HELP WOULD BE APPRICIATED
Old Feb 23, 2023 | 06:35 PM
Kwikkordead's Avatar
Kwikkordead
Did you test every gear before you put the transmission into the truck for correct engagement and function?
Old Feb 23, 2023 | 07:05 PM
helifixer's Avatar
helifixer
pull the top off of the transmission and make sure it is in netural
Old Feb 23, 2023 | 07:12 PM
hobohilton's Avatar
hobohilton
Clutch:
What did you change on the clutch "hydraulics" ?
Did you break any of the line loose ?
Did you remove a ZF 6 and replace it with another ZF 6 ?
How does the clutch pedal feel when depressed ?
Is there a chance you have air in the clutch hydraulic lines ?
Old Feb 23, 2023 | 07:57 PM
Dericksuperduty
Trailering
I SPUN IT BY HAND AND SEEMED OK
Old Feb 23, 2023 | 08:03 PM
85e150's Avatar
85e150
So it moves the truck in neutral? Or is it just spinning because of the internal friction and oil moving things?
Put another way, with the engine off and shifter in neutral, can you turn the ouput shaft? (Assumes no driveshaft)
Old Mar 12, 2023 | 05:01 PM
Dericksuperduty
Trailering
yes it spins freely
Old Mar 12, 2023 | 06:29 PM
hobohilton's Avatar
hobohilton
Before assembling, did you slide the clutch disc onto the splined input shaft of the transmission and spin the transmission over by hand while shifting it into each gear and reverse ?
Old Mar 13, 2023 | 09:46 AM
knottyrope's Avatar
knottyrope
clean out the clutch fluid and add in new
pull the slave and press in ten times then let extend and re install it
Clutchbuster
Jun 12, 2022 08:12 PM
geetoe
Sep 11, 2020 01:28 AM
Jespo80f150
Nov 15, 2012 04:06 PM
RyanMiller
Sep 4, 2005 11:28 PM
