Kick panel passenger side there’s this harness. I’ve seen people using it to install high idle mostly. I’ve even read somewhere the harness has to do with snow plow install. I haven’t found a clear explanation though as to what is for and what can you do with those wires. Can you point me in the right direction?
PTO and other integrations. The label on there will say what each wire does.
Yes this is where the high idle gets installed. I just did the BD kit last weekend.
