Headlight switch wires melting
Areas of melted wires:
Just showing where the blue/black wires plug into the harness.
'78 F100
Now to help to keep that from happening again and make the head lights brighter you need to add a head light relay kit.
I know LMC sells them and you can buy them on Ebay, I am using LMD as I have had it for years for a different project but got my 81 F100 on the road first.
It will send a full 12 volts to the head lights and the switch is only used to open & close the relay.
It is a plug & play install: unplug the head lights and plug the trucks plug into the relay harness.
The relay harness them plugs into the head lights.
Run power to the relays, has 2 one for low the other for high beam.
Runs 2 wires for ground and that is it.
I will say the relays are an odd size and if you need to replace them I got 2 normal size relays and 2 plugs to fit them.
I removed the wires from both plugs and swapped in the trucks wires into the new plug.
Now I can use normal size relay if I ever have to.
Oh how do I know this you ask?
I had a relay go bad because when I washed under the hood the relay filled up with water and stopped working.
Because I needed to use the truck before the fix I just unplugged the kit from the bulbs and plugged the trucks harness back into the bulbs and I had lights till I could fix the relay.
Dave ----
Thanks again!
The black elec tape right behind the plug looks to be PO installed or modified. Make sure nothing else if added or tapped into the wiring harness. Before you just black tape over it I would want to know WHY the wiring it getting hot and melting. FIRE HAZZARD.
Relay harness https://shop.broncograveyard.com/197...ctinfo/24800H/
Headlights https://shop.broncograveyard.com/LEN...artments/1085/
Awesome diagram in color. https://classiccarwiring.com/product...saAjkfEALw_wcB
Ok do I have your attention now?
None of them fancy glass leans with the even more fancy bulb that goes in from the rear.
I am really happy with the light out put with the sealed bulbs and relays.
When I use the truck to / from work I leave any were from 12 mid night to 3am so it is dark.
I would like to know what the voltage is at your head lights with out the relays as I know after it will be a full 12 volts.
If you lights are only getting say 10 volts they will be dim.
Dave ----
The truck also has 2 after market fog lights and a spot light. The spot light operates independently, but the fog lights can only be toggled on when the headlights are on. Makes me think they tapped into the headlight lines. I suppose the fog lights would need a separate relay connected to a 12V switched supply line, huh? Is that the right approach for wiring fog lights so they don't accidentally stay on when the truck is off?
For a spot lamp with it's own integral switch I would run off a dedicated fused lead to the battery.
In the case of your blue/black/melted insulation, if off the door /dome lights, since they have power even when the headlights are off, could be someone tapped into one them for an always available spot light feed. That melting could be "just last week" old ... or 20 years old?
I am with Tbear on the wiring of the fog lights.
If you run the fog light with a relay you can still have the head lights turn them on.
Just like the relay for the head lights the switch is not passing the power of the fog lights thru it, it is only the trigger to turn them on just like for the head lights.
Dave ----
I also reconnected my battery voltage gauge - However, it is now connected to an always-on feed. I've read this won't drain the battery if it's a mechanical dial. Any thoughts on that? I could track down a spare, switched source if that was better for the battery or gauge.
For headlights, you have the glass body sealed beams. In years of usage, they do dim some as the filament burns / ages. One day at my part time post retirement part time job I showed up early, it was still dark, buddy walking across the parking lot commented on my lit up grille. I knew my lights were dim, but they worked. I turned my headlights back on, took a look. Probably half of the reflector material had fallen in the sealed beam and the headlights were lighting up the radiator. I bought two new "Sylvania Silver Star" sealed beams and later that day, put'em in my truck ... next morning he was there again, he said "Wow". I told him that I felt like it was setting the grass along the ditches on fire now, they were suddenly so bright. I gave him the 20-25 year old ones, he wired them with a toggle to use in his old camper as overhead lighting. I'd rather have the glass sealed beams, no desire to be dealing with moisture or bulb changes through the back. I'd look for 6054H plain glass sealed beams, be they standard or Silver Star or ExtraVision ones. None of those LED things, etc ... if I had a '78 or '79.
An always connected battery volt gauge will represent a steady always low drain on a battery. If they didn't use current, they'd read right out of the box. It might run a long long time before it pulls a battery down, but it's pulling. The way to do it is use a relay that is tripped with a feed from the ignition switch accessory terminal, so it's only reading when the key is in and "on" something.
