electrical problems
Old Feb 22, 2023 | 10:58 PM
jc223513's Avatar
jc223513
6th Gear
electrical problems
i have a 1989 f-150 5.0 and i’m lost. it runs fine till you turn the headlights on. it didn’t start doing it till i put a new distributor in it. i will be driving and i turn my headlights on and you get over 2000 rpm it’s like everything dies even the motor and it won’t cut back on until i push the clutch in i’ve tried multiple things and still can’t get it figured out and now my headlights won’t even turn on i put a new switch in it and went through the wiring and replaced the fuse and they will cut on for a minute then cuts off and they won’t turn on same for the radio and interior lights. but when you it is warmed up fully it is fine.
Old Feb 22, 2023 | 11:08 PM
Prototypemech's Avatar
Prototypemech
You have two ground terminals to check.
The first one is behind the driver-side headlight.
The second one is by the battery on the inner fender well.
1. Remove the screw that holds the ground wires.
2. Shine up the sheet metal and the terminals with a small wire brush.
3. Reconnect everything back together.
Let us know if that fixes your problem.
Old Feb 23, 2023 | 12:40 PM
jc223513's Avatar
jc223513
6th Gear
i tried that and i didn’t do anything to it i clean both grounds
Old Feb 23, 2023 | 03:17 PM
Prototypemech
What do you mean " everything dies "? Dash lights? Radio?
Old Feb 23, 2023 | 08:15 PM
hobohilton's Avatar
hobohilton
Do you have a dimmer switch on the floor ?
Do some reading here... similar issues.
https://www.ford-trucks.com/forums/1...9-f-150-a.html
Old Feb 23, 2023 | 08:16 PM
jc223513's Avatar
jc223513
6th Gear
yessir the radio, the tack and the motor but when i push my clutch in it starts back up.
Old Feb 24, 2023 | 12:51 AM
Prototypemech
Yep. That's a weird one. My first thought is a mis-routed engine block ground and loose transmission bell housing bolts. Pressing the clutch separates the engine from the transmission slightly if the bolts are loose, and may restore a bad block ground.
You can test this by adding a extra ground from your alternator bracket to your negative battery terminal. See if that fixes the problem. And check your bell housing bolts for tightness. Please take a photo of your engine compartment and post it here.
Do you have to press the clutch to start the engine?
Old Feb 24, 2023 | 08:39 PM
jc223513's Avatar
jc223513
6th Gear
yes i have to push the clutch in to start it.
Old Feb 24, 2023 | 10:43 PM
Prototypemech
Try some of my other suggestions. And take a good look at your negative battery cable where it connects to your block.
Old Feb 24, 2023 | 11:27 PM
jc223513's Avatar
jc223513
6th Gear
that’s the computer i pulled it just to look and it looks like this
Old Feb 24, 2023 | 11:32 PM
Prototypemech
Open it up and look for damage.
Old Feb 25, 2023 | 07:59 AM
jc223513's Avatar
jc223513
6th Gear
Old Feb 25, 2023 | 09:33 AM
Prototypemech
Stick a fork in it. It's done.
Time to use the part number off it to find a new one.
If you're good with electronics and you want a science project, you might be able to use some isopropyl alcohol and a tooth brush to clean up the corrosion, and replace the capacitors. But it's faster and easier to find a working on on rockauto, eBay, or junkyard.
But that doesn't explain why your headlights and dash died. Those have nothing to do with the ECU.
I still think you have a grounding issue. Try running a secondary ground between the alternator bracket and the negative battery terminal clamp.
bbokainen
Mar 30, 2011 08:56 AM
Heffington
Oct 20, 2009 04:04 PM
95_4x4_jay
Aug 10, 2005 09:33 PM
fordboy1973
Jan 12, 2004 10:19 AM
