Second tank weight
Old Feb 22, 2023 | 11:30 AM
Brrt's Avatar
Brrt
Second tank weight
Both of mine currently work, but I heard of the rear tank frequently failing in F150s. The owner generally uses only the front tank and keeps the rear as dead weight. I wonder how much weight could be removed there and mpg added, and which tank would be best to keep. Keeping the weight in the middle seems like a good idea, but that is on the left side where the driver also sits. I can see a possibility of combining parts to make one working tank.
Old Feb 22, 2023 | 12:54 PM
sandymane's Avatar
sandymane
Best to leave it alone and not open that can of worms. Some like the weight of the rear tank being full and adding to a better ride. That is probably the reason the PO did it. I use both tanks and when one reaches 1/4 tank, I switch to the other. In the interim I run it till 1/4 tank. And then usually fill up both at a time to about 3/4 Full. These pumps get hot when you run below 1/4 tank so it is best to stop there. All this doesn't mean you shouldn't do what you want to do. I like a back up tank. The rear tank is no more prone to failing as the mid ship tank. Fuel weighs about 6lbs per gallon. I don't think there would be a significant weight difference to matter fuel wise if you didn't have a rear tank. Hope this helps.
Old Feb 22, 2023 | 02:19 PM
TexasGuy001's Avatar
TexasGuy001
From what I've seen the fuel pump in the front tank is the one that usually goes out first. Seen many trucks with original rear pumps. This is just about every one of these trucks that I have worked on.
If I was going to remove and bypass a tank it would be the front one. But, I would just keep both and fix or repair what needs to be done. I've driven trucks with just one tank and frequent fuel stops are not really fun. I also prefer having a tank to drive on if 1 pump decides to quit working.
Forget the dead weight thinking and just use both tanks normally. This keeps them from being nasty inside and keeps both pumps exercised.
If one starts to have the crossflow issue just run on the tank that fills up first so it won't overflow.
Old Feb 22, 2023 | 03:50 PM
Prototypemech's Avatar
Prototypemech
The actual fuel tank weighs about 30 lbs. I've never put it on a scale, but it's light enough (empty) to install it with one person's on their back.
Removing it won't save anything in the way of mpg. The truck is already nose heavy so a full rear fuel tank helps balance everything and provides more traction when things get wet or icy.
​​And fuel stops every 200 miles is no fun... So it better just to fix both fuel tanks so theyre usable.
Old Feb 22, 2023 | 06:02 PM
FuzzFace2's Avatar
FuzzFace2
That is the reason why I run the front tank down first.
Being I have a motor driven fuel pump I run the front down to "E" as I know I still have 5 gallons left in the tank just in case.
I then run the rear tank not as far down but "E" is also 5 gallons left.
With todays gas you dont want gas sitting around to long as it goes bad pretty fast so I would be using that rear tank but check just how bad the gas is if it has been sitting a long time. If it smells bad dont use it as it can gum up the valves and make them stick in the guides and could pull them out of the head.
Dave ----
Old Feb 25, 2023 | 07:04 PM
Brrt's Avatar
Brrt
I haven't filled both tanks yet because I thought of how much gas could be stolen. I will start using the rear tank more.
Old Mar 16, 2023 | 01:26 PM
Brrt's Avatar
Brrt
Ha. Now I am using only the rear tank, until I decide to spend for a new front tank.
Airborne-F250
18
Mar 8, 2017 07:45 PM
FordTruckGuy96
Jul 15, 2016 07:53 PM
trvlrerik
Aftermarket Products
Aug 26, 2012 10:54 AM
superduty4x4
Jul 20, 2008 04:04 PM
SDTruckMan
2004 - 2008 F150
Aug 13, 2006 06:52 PM
