Sponsored by: Real Truck
High boost with no power
Old Feb 21, 2023 | 09:11 PM
Sprimo1's Avatar
Sprimo1
1st Gear
Truck run horrible. Boost is almost on 40 blowing tons of white smoke no codes detected
Old Feb 22, 2023 | 07:41 AM
Antonm's Avatar
Antonm
You most likely have an internal engine issue, could be as simple a a valve spring but white smoke typically indicates a lack of compression in one or more cylinders.
Old Feb 22, 2023 | 08:49 AM
Dan V's Avatar
Dan V
Um....what engine?
Old Feb 22, 2023 | 10:34 AM
Antonm's Avatar
Antonm
Originally Posted by Dan V
Um....what engine?
lol, that was my first thought too, but considering he's talking about boost being at 40 , I figured its gotta be one of the four diesels that was available between 99-16. And since the 7.3 and 6.0 generally won't hit 40 psi and the engine is broken, I'm betting its an 08-10 with a 6.4 as those factory compound turbos will hit 40 psi in factory trim all day long and they break on the regular.
What's your bet?
Old Feb 22, 2023 | 10:43 AM
Dan V's Avatar
Dan V
No idea...but it's putting strain on the troubleshooting if you don't know the platform. He might have a 7.3 with the EBPV stuck closed...don't know if it will make 40psi though....and if it's 6.4.....oh brother.
Old Feb 22, 2023 | 10:59 AM
Antonm's Avatar
Antonm
Aw come-on,,,, if betting / gambling wasn't fun , people wouldn't be addicted to it. My money says its a 6.4.
rscperformance
6.7L Power Stroke Diesel
18
Apr 16, 2024 08:14 PM
SpikeRanch
Dec 15, 2022 02:31 PM
IronEagle1451
6.4L Power Stroke Diesel
Aug 26, 2021 06:25 PM
17f2fiddy
Sep 13, 2018 01:30 PM
johnkn
May 25, 2011 04:58 PM
