TED to replace
Old Feb 21, 2023 | 08:42 AM
dutch71's Avatar
dutch71
TED to replace
Hi everyone. My driver heating and cooling seat hasn’t been working for some time. A few days ago I had a garage performing a Forscan check and found out the blowing motor under the cushion has gone bad. Error called “thermo electric load open…”. I’ve searched and found detailed explanatory videos on how to replace the TED under the cushion. Some suggest to replace both TEDs at the same time, the one under the cushion and the one in the back of the seat cause if one goes bad the other might follow. The job as taking the seat out of the car and replace both TEDs seems not difficult. So far so good.
My question is after reassembling the seat and having hooked all harnesses back in place, can I start the car and use heating and cooling seats or do you need Forscan to clear all faulty codes first?
Thanks
Old Feb 21, 2023 | 09:37 AM
HRTKD's Avatar
HRTKD
If you have FORScan (doesn't sound like it), clear the codes. Otherwise, usually the truck will reset itself for many of the codes that get logged.
Old Feb 21, 2023 | 10:31 AM
dutch71's Avatar
dutch71
You're correct I don't have Forscan. You say after a while the truck will reset the fault codes of the TEDs by itself if not done via Forscan?
Old Feb 21, 2023 | 10:46 AM
Painted Horse's Avatar
Painted Horse
Forscan is free for 30 days (I think ) and very inexpensive to buy a 1 year license. The hardware to connect your laptop to the obdii port is $30-$80 depending on what you buy.
In total pretty cheap and you something you can read and clear all future codes that may pop up. Just spend the $30
Old Feb 21, 2023 | 10:51 AM
HRTKD's Avatar
HRTKD
I don't know if THAT specific code will clear itself. Some codes do clear themselves. In other words, run with it and see if it clears on its own. If it doesn't then you'll need to see the dealer or buy FORScan. The definitive thread for coming up to speed on FORScan can be found in the link below.
https://www.ford-trucks.com/forums/1...ces-index.html
Old Feb 21, 2023 | 11:04 AM
dutch71's Avatar
dutch71
Thanks everyone
D3thM3tal
Jan 27, 2019 09:48 AM
SonofaFord
Apr 25, 2016 04:23 PM
fr87hn
Dec 8, 2005 05:53 AM
redwingsfan
Oct 3, 2005 07:39 AM
zoti
May 11, 2005 10:32 PM
