Heated Seats
Old Jan 25, 2005 | 09:27 AM
redwingsfan's Avatar
redwingsfan
Heated Seats
My heated seat on the drivers side quit working. I swapped the controllers and it still does not work. I have been told that it is probably the element which I understand requires replacing the seat covering. Has anyone done this? How hard is it to do?
Old Jan 25, 2005 | 04:42 PM
industrialjunk's Avatar
industrialjunk
I've done it, pretty simple you'll need some hog rings to put the seat cover back on. Once you take a look at the seat it be fairly obvious how it comes apart and what you will need to do it.Takes about an hour per seat.
Old Jan 25, 2005 | 07:24 PM
JWK0721's Avatar
JWK0721
It Is A Pretty Simple To Replace The Element In The Seat. Make Sure You Have The Hog Ring Pliers Otherwise It Is A Little Difficult.
Old Mar 7, 2005 | 09:51 AM
The Miker's Avatar
The Miker
Where did you get the replacement element and how much did it cost?
Old Mar 7, 2005 | 02:14 PM
rozett's Avatar
rozett
Miker, you luck out. in 2000 and '01, the element was molded right into the seat cushion. That means replacing the cushion and element at about $150. With an '02, you should be able to buy the element alone at about $50 and replace it yourself.
Old Sep 22, 2005 | 08:39 AM
bnuvp's Avatar
bnuvp
With winter just days away here I wanted to fix my driver's side heated seat on my 2000 EX. What's involved with replacing the cushion?
Old Sep 23, 2005 | 08:15 AM
JScritch's Avatar
JScritch
This is not correct. In my '00 the element is seperate from the cushion/cover and could be replaced by itself.
I had a problem on mine where the wire connecting the seat element to the back element had broken. I re-soldered it and everything worked great again.
Just do a little investigative work before spending $$. A little time and and a voltmeter can tell you a lot.
Old Sep 23, 2005 | 08:25 AM
clevelandjim's Avatar
clevelandjim
Ayone have a solution for a seat that barely get warm after 10 minutes of warming?
Old Sep 23, 2005 | 08:32 AM
bnuvp's Avatar
bnuvp
Thanks for the tip, that sounds incouraging. I'll put a new battery in the volt meter and check it out.
Old Oct 2, 2005 | 10:20 PM
bmenzel's Avatar
bmenzel
Are both the seat cushion AND the seat back heated in the 2005 Ex? Thanks
Old Oct 3, 2005 | 07:39 AM
bnuvp's Avatar
bnuvp
I couldn't find any broken wires. Came across two that were bent back 180 degrees. Fixed that but still no heat. How can you tell if the heating element is seperate? I couldn't see anything that looked like a heating element.
