4spd 460
Old Nov 15, 2003 | 11:25 AM
highrider76's Avatar
highrider76
Question 4spd 460
4spd 460
I have a 1974 f250 4x4 with a four speed. (granny low)
the engine is shot and i have a 460 sitting around.
i want to put the 460 in and keep the 4spd.
is there a bellhousing for this application or is it like the c-6 with an integral bell housing tranny case.
highrider76
Old Nov 15, 2003 | 11:32 AM
nbaff's Avatar
nbaff
Well, from the infomation that I have heard or read. If you orginally had a 351M/400M the motor will bolt to the transmisson. Since the 429/460 have the same bell housing pattern at the 351M/400M. But if you have a different engine than those. You will have to change the bell housing. There are other modifications that must be done to fit a 460 other than the bellhousing pattern.
Old Nov 15, 2003 | 11:23 PM
olfordsnstone's Avatar
olfordsnstone
Yup, you may need to change the bell housing, depending on the current engine in place. The motor mounts and exhaust will also need to be modified. I went to Hooker for both mount brackets and headers and am very happy with these. Then took her to a reputable exhaust shop to mount dual exhaust to drop just before the rear axle. Get a heavy duty clutch to install though. The one I used slips and I am unable to step into it as much as I would like. An earlier posting recommended a Centerforce clutch. Good Luck
highrider76
Mar 8, 2004 10:36 PM
highrider76
Nov 15, 2003 09:13 AM
